Question about Samson C01U Consumer Microphone
SOURCE: Samson co1u recording issue
Microphones are not stereo! There's only one channel because there's only one mic.
Don't touch the pan control. You
should only be recording from the left channel and then playing it back
in stereo to hear the same thing in both speakers. When you set up the
mic for recording, choose "mono mode" or "left channel only".
Posted on Mar 28, 2008
SOURCE: Problem with Samson CO1U
Of course it's going to be quiet if you don't turn up the volume.
You don't need SoftPre. Just increase the gain of the mic using the
normal gain control. Go to Control Panel --> Sounds and Audio
Devices --> Audio tab. Select Samson C01U as the Sound recording
device and then press the Volume button. Slide the slider more near
the top.
SOURCE: Cannot hear sound from mic
i can't install logitech desk mike model ak 5370 in vista
Posted on Jan 04, 2009
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Posted on Jan 16, 2009
SOURCE: SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Posted on Feb 10, 2009
Apr 04, 2010 | Intel Steinberg Nuendo AudioLink PCI 96...
Feb 20, 2010 | Samson C01U USB Condenser Microphone...
May 23, 2009 | Samson C01U Consumer Microphone
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Jan 03, 2009 | Samson C01U Consumer Microphone
Jan 03, 2009 | Samson C01U - USB Studio Condenser...
Sep 01, 2008 | Samson C01U - USB Studio Condenser...
May 01, 2008 | Computers & Internet
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Jun 01, 2014 | Samson C01U Consumer Microphone
Mar 15, 2013 | Samson C01U Consumer Microphone
Feb 04, 2013 | Samson C01U Consumer Microphone
51 people viewed this question
