Question about Apple iPod nano 5th Generation
HI; There
are two different ways to delete songs or playlists
and revise your iPod with iTunes. You can do this automatically
or manually, whatever type of technique you may choose depends
on the preferences that you set up in iTunes. Unless the settings
are in iTunes, it will automatically update the iPod when you
go to hook it up to your computer after you have followed the
steps to delete songs and playlists automatically. If you cannot
do this, you should follow the instructions for doing it the
manual way. There is a setting that can be set so that the iPod syncing
preference is in iTunes. To do this, you need to connect the
iPod to the computer. Open iTunes and select iPod in iTunes
source list. Press the option button in far right bottom corner.
The option button won't appear if the iPod was not selected
in the step from above. iPod preference window appears. Click
to select automatic option or manual update option. If the
select "Automatically Update Selected Playlist Only" option
is chosen, make sure playlist that you want to delete from
your iPod is not selected. You can have songs or playlists automatically
deleted. Open
up your iTunes. Pick a song or playlist that you would want
to delete from your iPod. Then from the edit menu, choose clear
or press the delete key. If a dialog box appears pres yes.
Song or playlist should be deleted from iTunes. If the connection
from the iPod to the computer chooses to update the songs on
your iPod from file menu or the connection from your iPod to
the connection to your iTunes will automatically revise iPod
and delete songs or playlist that was deleted from above. When you are ready to delete songs or playlist manually, open
iTunes. Select iPod in source list. Choose song or playlist
you would want to delete from iPod. Deleting playlist or a
song from playlist will now get rid of song from iPod. Next go to edit menu, choose clear or press delete. Press,
"yes" if dialog box appears. The song or playlist should be
deleted from the iPod. Manually deleting songs or playlists
from iPod you do not want to delete a song or playlist from
iTunes. Deleting a song from playlist will not eliminate song
from iPod. Choose iPod in iTunes source list and find song
that you would like to delete. Do not format iPod to erase songs or playlists. Do not use
any sort of disk utility programs like Disk Utility, Drive
Setup or Windows Explorer to wipe out iPod. Wiping out songs
this way can hinder the iPods music playing capabilities and
you may have to revise or reset your iPod to get it to work
properly again. To reset iPod with Scroll Wheel and iPod with Touch Wheel: Connect iPod to power adaptor and plug into an outlet or connect
iPod to Mac's built in FireWire port. Press the Hold switch on & off. For about 6 to 10 seconds press and hold Play/Pause and the
menu button until the Apple logo can be seen on the screen.
Repeat these steps if necessary. To reset iPod with Circle Wheel: Connect iPod to power adaptor and plug into an outlet. Press the Hold switch on & off. For about 6 to 10 seconds press and hold play/pause and the
menu button until the Apple log can be seen on the screen.
Repeat these steps if necessary. To reset an iPod with a Click Wheel: Press the Hold switch on and off. Press and hold for about 6 to 10 seconds the menu and select
buttons until the Apple logo appears on the display screen. With all the tips from above, your iPod will have plenty of
free space and work like new. hope this helps you................
Posted on Sep 17, 2011
Hi inthebag pik...
Try this easy way to delete your unwanted songs...
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
You have to do it when you hook it up to your computer
Posted on Sep 26, 2011
SOURCE: can i put new songs onto my ipod without the other ones deleting?
EACH TIME YOU HOOK UP TH EIPOD IT REINSTALLS ALL THE EXISTING SONGS ALONG WITH NEW ONES. YOU CANNOT DELETE THEM AFTER YOU INSTALL THEM OR THEY WILL ALL BE DELETED THE NEXT TIME YOU HOOK IT UP.
Posted on Jul 27, 2007
SOURCE: IPOD Shuffle deletes songs if I delete them from the music library in Itunes
You have to keep all the songs that you want on your iPod on your computer, otherwise you will get this problem. So if you want song "a" on your iPod it must also be in your iTunes library at all times unless you don't want it on your iPod anymore
Posted on Oct 03, 2008
SOURCE: all my songs deleted from my ipod
Try the link.It may help.
http://www.recovermyipod.com/
Posted on May 31, 2009
Feb 08, 2017 | Apple iPod Audio Players & Recorders
Sep 07, 2016 | Apple iPod nano
Jan 30, 2014 | Apple iPod shuffle Second Gen. Silver (1...
Jul 30, 2012 | Apple iPod touch
Apr 30, 2010 | Apple iPod touch
Oct 24, 2009 | Apple iPod nano
Sep 07, 2009 | Apple iPod nano
Jul 04, 2008 | Apple iPod nano
Apr 03, 2008 | Apple iPod nano
Mar 23, 2008 | Apple iPod MA446LL/A MP3 Player
324 people viewed this question
