SOURCE: securing my wireless linksys BEFW11S4 ver. 4
I’ll be pleased to help if I can. To answer your last question first, this router is already set up for wireless networking, so nothing further needs to be done with regard to that.
However, to prevent others using your connection, it's necessary to set up wireless security. There are four main steps, which are the same for most routers:
1) Login to your router, using a wired connection
2) Change the router login password
3) Change the network name (SSID)
3) Enable WPA encryption
Here are the details:
1) Login to your router, using a wired connection.
First, you will need an Ethernet cable to connect one of your computers to the router. This cable just plugs into a spare port on the back of your router, while the other end plugs into the Ethernet port on your computer (looks like this picture).
When you are connected, open a web browser on your computer. Type the router’s IP address into the address bar, which is http://192.168.1.1 for this model. (Note, there is no ‘www’)
You should then see a popup box, prompting you for a username and password. If these have not been changed, leave username blank and enter password: admin
If you log in successfully, you should then see the Linksys router configuration screen.
2) Change the router login password.
To set a new password, go to Administration > Management. Set and confirm a new Router Password. On this screen, I would also recommend that ‘Remote Upgrade’ and ‘Remote Administration’ are disabled. Click ‘Save Settings’ when finished.
(Tip: write the password on a label and stick it on the router, or keep it somewhere safe. )
3) Change the SSID (router name):
Go to Wireless > Basic Wireless Settings. Change the ‘Wireless Network Name (SSID)’ from the default, to anything you like, that you can remember. It is case sensitive, and you can use up to 32 letters –but do not use something that could identify you, or your location.
At this stage I’d recommend that SSID broadcast remains enabled.
4) Enable WPA encryption
Go to Wireless > Wireless Security. Enable Wireless Security. Under ‘Security Mode’ you have a number of options for encryption, but I would pick WPA-Pre-Shared Key, which is very secure and good for most equipment.
Under ‘WPA Shared Key’ you need to enter a network key. This is a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers
( eg: 456the51stSTATeOFtheUSA1599 ). It is case sensitive. The stronger the network key the better, if you are very concerned about security.
Note down the network key carefully. You will need this to connect wirelessly. (The network key may also be called the WPA shared key, PSK, WPA-PSK, pre-shared key, security key, passphrase, or authentication key). Click ‘Save settings’ when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you should see your network with its new name in the 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work, or if you need help with any of it.
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
SOURCE: Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
SOURCE: Multiple networks appear after reboot on lan desk
the reason could be the networks scanned by your wireless card when it starts up. What you could do is go to select your preferred netwrok and bring it to the top of the list . ( In the wireless configuration utiity ).
Thanks
Ranjit
SOURCE: I have installed a Netgear
Check firewall settings in vista, might need to create exemptions to allow access. Check Antivirus settings in vista, might need to create exemptions. Quick test is to switch off both antivirus and firewall in order to establish connection. Also check if there is a newer wifi driver for your laptop.
