Question about Sony KV-32FS13 TV
Sony kv35s26 TV: no picture, audio works, stanby light blinks continuously. I have a Sony Trinitron pulled elect plug after 15 seconds repluged and got a picture which soon went out. Now still no picture. Prior to going out completely vertical lines were in the bottom half of the screen befor it went out completely black again.
1 Related Answer
ABRsvcs
  • 4234 Answers
SOURCE: Sony kv35s26 TV: no picture, audio works, stanby light blinks.
First a couple of questions:
1) Does the standby light blink continuously or is there a repeating pattern?
2) If there is a pattern, can you please post the blink count?
With the above information, I should be able to provide you with a couple of possibilities as well as a few tests to perform. Please update this and we'll continue to try and resolve this.
Thanks,
Dan
Posted on Jan 19, 2009
Sony trinitron kv35s26 no high voltage.
Continuous blinking of standby light to Sony TVs indicates a fault with its II2C bus. Your set need an through checkup, which can only be done by any experienced service technician. Anyway, try the site linked here, and see is there any details which could help you. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
Dec 21, 2012 | Televison & Video
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why power/stanby blinks light red
how many times does it flash? The back of the manual will usually tell you what the flashes mean. Try this: unplug tv from power. While unplugged, hold the power button in on the TV, not on the remote! Hold for 10 seconds. Replug the power and try to power it up. If you get no picture, you need a repair. Contact the manufacturer for an authorized servicer.
Jul 19, 2010 | Sony KDF-E42A10 42 in. LCD Television
Pictures not appear
this could be a leaky picture tube. will require a crt rejuvination machine to clean the tube elements
Dec 28, 2009 | Sony FD Trinitron WEGA KV-29LS35 29" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Thanks,
Dan
Jan 19, 2009 | Sony KV-32FS13 TV
Sony trinitron kv35s26 (August 1997) no video, only audio
this is the best out there , but you will have to use one with the same chassi #
http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
glad to help! plz give time for a good rating, thanks , j (electech)
what another models fault is in the video, should help find you find problem
Sony
Model:kv32s45
Chassis:AA2d
No video, Has High voltage. Turning up G2 show a very dim full raster and on the sides a very bluish faint bar .
Replace Vert. IC561 (TDA8172)
Comments:
need any more help just ask , thanks
electech
Oct 29, 2008 | Sony KP-65XBR10W 65" Rear Projection...
My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light...
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Oct 20, 2008 | Televison & Video
1999 Sony Trinitron TV. We have sound but no picture. Stanby light is flashing?
How many times does the light blink. It should blink a code 1-8 blinks pause a second then blink the code again. Count the blinks then let me know. If it just blinks constantly without pausing. let me know that as well.
Jan 19, 2008 | Televison & Video
Sony KV-32FS13 TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
