Question about Mitsubishi WS-55511 55" Rear Projection Television
I have a WS-55511 rear projection TV. We had a power outage in the area and the TV will not power at all. Could this be a blown fuse?
Posted by rj_mallette on
  • rj_mallette Sep 19, 2011
    Thanks for the help. I did find a replacement for the 10A fuse next to the power cord, but it did not work. The TV will still not power up. Not surprising as the fuse still looked good. I also looked at every other fuse on the boards and the all looked visibly good. Not puffed up or anything. I did not look at anything in the DM as that is a little harder to get too. As far as green lights, etc, my front console died a couple of years ago, so I disconnected it so I could still turn the TV on with the remote. It's a shame if I can't get it working because of a power surge, because it was a fantastic TV for years and still has a perfect screen and picture.
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If the green power light just blinks that is one issue==========if the green power light does not come on at all suspect a fuse----follow the power cord (set unplugged) into the set and plug in ac fuse is right there.
If you have the blinking light that will not stop it means the DM unit in the set was damaged and that is expensive.
If you need more information or have questions let me know with a comment here.
SD TECH
Posted on Sep 17, 2011
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
Sep 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tv is not working will not turn on ,the green light is blinking, this happened after a power outage
I have a 26 year old TV... It is a RCA color track 2000. it will not turn on. Can anyone help?????
Apr 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The power outage went out yesterday and my tv wont turn on
Most likely it is capacitors on the dm board that have gone bad. This is a fairly common problem and has been addressed on fixya many times. If you know someone who is good with soldering and technically incline or even an honest electronics guy then the repair is quite cheap. If you have any other questions please let me know. if its not the capacitors on the DM supply then its a problem with the whole DM assembly that part usually is around 300$. So you may want to consider purchasing a new tv. Trying the 7 caps on the dm supply board shouldn't cost much if it takes anything more then that. I would sell the tv on craigslist or ebay and recoup as much as you can towards your next tv.
thank you,
lee
Thank you,
lee
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
MY MITSUBISHU WS 55511 WHEN POWER TURNED ON WILL
I have the same set doing the same thing. I will replace IC and fuses to see if that will fix it.
Jan 05, 2010 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 shuts off with in 1 secound when turned on.
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My 2002 ws55511 during a power outage turned off and will not turn back on, i have tried to diconnect tv for several hours and up to several days and plug back in, green light blinks for 30 seconds or so...
This same problem happened to my 55511 about two years ago. It appears to be a software issue. I ran the built in self test and it corrected the problem. Have you tried this?
May 06, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blinking green led on WS-55511
You have two different model numbers lisdted and they are both different repairs.
Jun 17, 2008 | Mitsubishi WS-65513 65" Rear Projection...
MODLE NUMBER WS-55511
Missing voltage = open fuse in power supply?? soldered-in
pico fuse?
Does light blink continuos up front?
Can you hit power again with same result or must unplug/plug
AC cord??
Oct 24, 2007 | Mitsubishi WS-55515 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
