Vizio GV47LF Television Logo
Anonymous Posted on Apr 08, 2017
My Vizio GV47LFHDTV10A turns itself off. Once the touch screen On button is pressed an audible click is heard, the front panel "Vizio" turns white, then about 2 seconds later another audible click is heard and nothing further happens, powers itself off. It sounds like some kind of self-check circuitry is turning itself off. I've pulled the back cover and no no obvious capacitors what may have blown on the power board, and have checked the surface mount fuses on the main board. I suspect either the Power or Main board, don't know how to determine which may be bad or if I'm on the wrong track. any help is appreciated!
5 Related Answers
A
Anonymous
  • Posted on Apr 13, 2008
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Anonymous
  • 2712 Answers
  • Posted on Oct 29, 2008
SOURCE: No Picture
I would check the soldering first for any cracks, and any obvious faulty capacitors or components. It looks like the power board is going into a protective mode because of a short / failed component somewhere.
It would be virtually impossible to guess exactly where with a spot check..
Anonymous
  • Posted on Mar 21, 2010
SOURCE: vizio gv47lfhdtv10a no picture no sound
Well guru way to help him out with his problem maybe he doesnt have the money to just run out and buy a new one...
W.L.
  • 2511 Answers
  • Posted on Feb 04, 2011
SOURCE: VIZIO M ODEL
Have you tried changing source or input? regards
Anonymous
  • 29 Answers
  • Posted on Aug 20, 2011
SOURCE: Vizio VX37L HDTV10A no picture
Hi.
You need change the Main board. You have a micropros. problem.
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
My vizio gv47lf turns itself off. once the on button is pressed a click is audible, the visio lights turns white, and approximately 4 seconds later another click is heard but never any picture or sound....
It can be power supply failure due to bad caps, or it detects shorted circuits in the set so it goes into shutdown mode.
Look at the power supply first for any bad caps, burnt components, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Our Vizio was operationing normally when suddenly, we heard a "vaccuuming sound" that was emitting (until the plug was pulled). We now cannot use the buttons. Sometimes we get the "no...
this could be one of two problem one being a capacitor that has failed it the power supply
Very common or a diode has failed and for that you will need a tech the cap may be replaced by your if you can solder the cylinder shaped part will have a domed top while the good one will be flat the value of the part will be printed on the body go to your local parts store for about 50 cents you will be good to go
3helpful
2answers
I have a 37" vizio. I was switching input form tv
Press the input button and the set will turn on. Keep pressing the input button until the correct input is selected.
21helpful
2answers
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
1helpful
Dryer does not start up when the start button is pressed. It makes a click like a relay is closing but no power to the drum motor, or electric heat. unit interior lights up, and controls light up. When...
Your belt is likely broken. Pop the top (held down by spring clips) to inspect. If you see it - try to lift it. If you can not lift it it is ok. If not ok, remove the front cover for complete access to the drive.
4helpful
2answers
Vizio gv47lfhdtv10a no picture no sound
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
