Posible the bands are slipping / valve body may also be sticking or going bad under temp causing your problem you may have to take to trans shop to have checked
I used to have similar problems with a 1998 Dodge Caravan. The problem we had with the Caravan, was that the transmission (******) fluid was low (we had to put about a quart of ****** fluid in every two weeks, it leaked so much). Check the ****** fluid to see how low it is. If it's low, then add some. ****** fluid is cheap. If you can, find where it's leaking from - then it will save you money in the long run (we were never able to find out where our leak was..it was a bummer). Hopefully this helps.
