SOURCE: Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank [email protected]
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
SOURCE: Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
SOURCE: GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
SOURCE: my second handset is disfunctional
you have to put the second handset on the primary base for about 20 seconds for it to accept it, then you will get a tone and everything should work fine from there.
