Question about Motorola Mag One BPR40 Two Way Radio
How do I connect Mag One BPR40 two way radio by Motorola to CP100 two way radio by Motorola? I already had about 8 CP100's and we just got 2 new Mag One's. Thanks.
Posted by mike81431 on
eradiostore
  • Motorola Master
  • 1,658 Answers
The Mag One BPR40 is dealer programmable. You have two choices:
1) Reprogram your CP100s to match the new BPR40s. For this you would need to know what the dealer programmed the BPR40s to... OR
2) Take your BPR40s back to the place of purchase and request they reprogram them to match your CP100s. This should be a free service since you just purchased the BPR40s. They will need to know some settings from the CP100s to make the match.
Best regards.
Posted on Sep 19, 2011
Mag One BPR40 not powering
Contact Motorola Solutions (http://www.motorolasolutions/support)
Jun 26, 2014 | Motorola Mag One BPR40 Two Way Radio
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
Fuse Location on Mag One BPR40
these usually use a diode for reverse polarity protection and no fuses. You will need a full schematic and probably a service manual.
Oct 14, 2013 | Motorola Mag One BPR40 Two Way Radio
Green light stays on bpr40
If this is after programming your radio needs repaired. We see this when some BPR40s are reprogrammed. Take the radio to your local service center or send to a qualified repair center.
Sep 12, 2013 | Motorola Mag One BPR40 Two Way Radio
Mt mag one bpr40 uhf 450/470 will receive but will not transmit. green light is on all the time
It probably has "busy channel inhibit" turned on in the menus, and the squelch is open, thus making it think there is a signal on the channel you're trying to use.
Sep 01, 2013 | Motorola Mag One Bpr40 Uhf 4w 8 Channel...
My mag one bpr40 will not transmit. the green light is on all the time. it will receive. how do i fix this problem
Green light coming on and staying on... Sadly nothing the end-user can do to alleviate this problem themselves. It is usually repairable by a trained/equipped repair facility.
Sep 01, 2013 | Motorola Mag One BPR40 Two Way Radio
Have two bpr40 need to find out the frequencys
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
Aug 20, 2013 | Motorola Mag One BPR40 Two Way Radio
Bought a used Motorloa Mag One BPR40 at a tag sale and then bought a new one. The used one looks like it was used by a business so it was probably "programmed." How do i get the two BPR's...
Your radios will need to be programmed by a Motorola dealer to match one another. (Usually $15-$25.) The software used to program the radios is a Motorola proprietary software and not for sale, but most dealers have a subscription to it.
The loud buzzing indicates the channel you are on is not programmed.
Best regards.
Aug 10, 2011 | Motorola Mag One BPR40 Two Way Radio
We use these radios in a race car.They work fine until you hook up the headset for the spotter to use and it drains down the battery real fast.Brand new batteries.
It is possible the headset you are using is not the one engineered for the radio, and draining the battery. Or this radio is being transmitted on heavily and running down the battery. You might try changing headsets and see if the problem clears up. Not all headsets compatible with other Motorola Radios will work with the BPR40.
Best regards.
Aug 01, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
288 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
