Question about Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I have both units on the same channel and both units are in the same location as before. The remote unit is showing the outside temp correctly and the main unit is showing all other items (inside temp, time) correctly-just can't get the main unit to pick up/show the outside temp.
Posted by Barbara McCaa on
  • 3 more comments
  • Joe Barinas Nov 20, 2011
    What have you done to solve your problem?
  • Anonymous Mar 14, 2014
    Oregon Scientific Weather Station BAR206A will not show outside temp on the inside unit
  • Anonymous Mar 17, 2014
    433MHZ Cable Free
  • Anonymous Mar 29, 2014
    Does not show wind speed or direction, amount of rainfall, barometric pressure, outside temp. or humidity, and forcast does not change.
  • GarbageCzar Sep 11, 2015
    I was having this problem with a similar model. Solved it just now by (1) removing then returning the batteries in the indoor unit (2) doing the same for the outdoor unit. In a few seconds, both temps were displayed.
Flying Dragon
    New Friend:
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Posted on Sep 23, 2011
I have a model 9125itc thermometer. The outdoor temperature is not showing on neither indoor or outdoor instruments. all I am getting are - - bars. I have installed new batteries
  • Remove all batteries
  • Install batteries in outdoor unit and allow time for it to begin transmitting temperature data
  • Install batteries in indoor unit. You should see outdoor temperature displayed. If not, the outdoor unit may be defective
Dec 23, 2017 | Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
Taylor 433MHZ cable free thermometer won't show outdoor temp
Check battery in outdoor sender and reset main unit to receive transmission of data. If nada could be that you have an issue either with the sending unit or the receiving unit of your weather station. Has happened to me a few times already so .................
Jan 22, 2013 | Measuring Tools & Sensors
I changed batteriers and now I can't get a reading from the remote. I have hit the reset on both units. Maybe not in the righ order.
I believe they ask you to press the reset button on the main unit first, but that may not be your problem. Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. Also, make sure the units are close enough to transmit.
Sep 26, 2010 | Oregon Scientific RMR382ABLACK Wireless...
I have a equitytime thermometer and can't find the instructions for it. I just changed the batteries and can't get the outdoor to send a signal to the indoor unit. where can I find the instructions for a...
Take the batteries out of both units (the base and the outdoor thermometer). Put the batteries back into the outdoor unit, and then put the batteries back into the base unit. This worked for me.
Apr 07, 2010 | Kitchen Appliances - Others
My indoor outdoor thermometer is only displaying the inside temperature and I lost the manual and can't remember how to reset it?
often removing the batteries in both units will reset. replace batteries in indoor unit firs, let it settle down then insert batteries into outdoor unit. There may be a button on outdoor unit to initialise the connection.
Alternatively you might find the manual here or get the instructions from their support.
http://www.orbyxelectronics.com/manuals.asp?choice1=3&choice2=14&hidPickIndex=2
Nov 04, 2009 | NexxTech (NOMR)
GE Digital Wireless Thermometer
Wireless Digital Thermometer GE5805WS4
Instruction Manual
Buttons and Functions
Button Function
Front of unit:
Min/Max...........displays Min or Max temps recorded
CH(Channel)......changes displayed channel
(hold 3 sec to erase)
Clear................clears memory in Min/max display
Back of unit:
C/F....................Toggle between Celsius
or Fahrenheit temperature display
Scroll.................Remote Channel Scrolling ON/OFF
INSTALLING BATTERIES
IMPORTANT:Read the section SETTING UP THE THERMOMETER before installing the batteries for the first time.
1.Remove the rear cover of thermometer. Install 2 new AA batteries. Replace battery cover.
2.Loosen 4 screws on rear battery cover of the Remote Sensor and slide battery cover off.
3.Install 2 new AA batteries .
4.After batteries are installed, the remote sensor will begin transmitting and automatically register to the Thermometer
(within range) after several minutes. However, you can also press the small button in the battery compartment (labeled Tx) to register the Remote Sensor to the Thermometer immediately
5.Replace battery cover and tighten 4 battery screws. Make ure that the battery cover is fully on and tightened to assure a watertight seal.
The thermometer can monitor up to two different Remote Sensors on two separate channels. Add-on remote sensors can be purchased separately and are compatible with the GE Wireless Thermometer/Clock (model GE5805WS4) as well as this unit. When first installing, always insert batteries into the Thermometer first, then into the Remote Sensor.
The thermometer uses random security code technology-it will learn the random code of the first Remote Sensor it detects and log in as channel 1. Channel 2 will register in the same way. NOTE: Registered channels will be erased when the batteries of the Thermometer or Remote Sensor are removed. When replacing batteries for a Remote Sensor, remember to clear the corresponding channel of the Thermometer in this way:
1.Remove batteries from the remote sensor (step 2 of installing batterie)
2.Select the channel that you would like to clear by pressing the CH button on the Thermometer until this channel number is displayed.
3.Hold the CH button for 3 seconds to clear the channel
4.Follow steps 3-5
MOUNTING THE REMOTE SENSOR AND THERMOMETER
Remote Sensor is suitable for outdoor mounting (watertight) at a range up to 100 feet from the Thermometer. HOWEVER, HE UNIT SHOULD NOT BE MOUNTED IN A POSITiON WHERE IT WILL BE SUBMERSED IN WATER, OR EXPOSED TO DIRECT SUNLIGHT, OR NEAR OTHER SOURCES OF HEAT OR COLD (I won't bother typing the rest) except for:
LOW Battery icon for the sensor will show up on either the
ch 1 or ch 2 display depending on which sensor is losing battery power.
Battery life 6 months
Temp Range Therm 32 to 122 deg F
Remote Sensor -58 to 158 deg F *
*Alkaline batteries can freeze temporarily at temps below -4 deg F. In this condition, the Remote Sensor cannot accurately transmit temp info to the Thermometer. This limits the effective minimum temp fo the Remote Sensor to -4 deg F
Operational Range....>50ft(and up to 100ft)(less interferances)
RF Channel ....refresh to "---" if no signal received in 60 minutes
Jan 06, 2008 | Heating & Cooling
Oregon Scientific Wireless IndoorOutdoor Thermometer with Atomic Clock Sync Logo
6,300 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
