Question about Stanley Garden
I need an owner's manuel for a Stanley router.The type-model# for the motor is H258A; the type-model# forthe base is GA-H279A; the type-model# for the guide is GA-H280A.
Posted by wwd25 on
richie46
    Top Expert:
  • Stanley Master
  • 12,962 Answers
Try manufacturer web site.
Posted on Jun 12, 2016
Manuel reparation pontiac sunfire
Download the Owners Manual from the link below.Select the make year of your model and then the model type[Sunfire].Click on the Owners Manual that appears below 'Related Sources'.
www.pontiac.com/owners/owner_resources/manuals.html
Hope this helps.Thanks!
Kenneth.
Jan 09, 2012 | Cars & Trucks
I inherited a stanley industrial drywall screwdriver model 90541 volts115 rpm 1800 with no instruction manuels or bits. where can I find the instruction manuel ?
Stanley is usually very good at keeping PDF's on their site for most all products, but I could not find reference to this model. Verify the model number is correct, and try one of these numbers: Canada: 800-463-9872 U.S.: 800-262-2161
If you prefer e-mail contact, here is the link to their site:
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
This may not be the answer you were hoping for, but the service staff are really easy to deal with and I'm certain they will be able to help you out.
Apr 09, 2011 | Stanley Hand Tools
I BROKE THE PLASTIC BASE PLATE OF A BLACK AND DECKER ROUTER MODEL 7613 TYPE 4. DO NOT HAVE AN OWNERS MANUAL TO IDENTIFY THE PART NUMBER TO ORDER A REPLACEMENT FOR IT.
go to Dewaltservicenet.com and type in your model number and it willl ask for the type number and you can download a manual and also a breakdown for this tool. they also have a locator for local vendors who carry their product.
Jan 09, 2011 | Black & Decker 11A 1 Router
I have a Stanley 4.0 peak HP wet/dry vacuum without any instructions. How do I empty it when it is full?
Usually with this type of vacuum the the top motor part unclips then tip the base unit over into an outside drain.
Jan 02, 2011 | Stanley SL18128P Wearable WetDry Vacuum
I need an owners manual for a Craftsman Router model 315.17491.
sears.com go to toolsthem go to manuels and then downloads. then add your model number or the root model number for jointers like yours and you can get the free downloal, as long as the machine isn't older that the age of computers 1975 or about.
Jun 12, 2010 | Craftsman Push Block, Jointer Hold Down
I cant load the brads
You can go to http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
Click on Knowledge base and search for your model. I found it but I am unable to attach a copy here.
May 05, 2010 | Stanley Electric StaplerNail Gun...
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
Oct 01, 2009 | Porter Cable 690LR Router
2001 saab 9-3 fuel door will not open
May sound a little stupid im just trying to cover all bases but have you made sure the car is unlocked. If the car is locked then the fuel door will be locked.
Apr 26, 2009 | 2001 Saab 9-3
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
Garden Logo
478 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
