Question about Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582
I am trying to find the exhaust manifold or whatever the pipe is that comes out of the generator and connects to the muffler tube, I have a generac np50g, any ideas where i can find it?
Posted by aaron dodson on
  • aaron dodson Sep 17, 2011
    I am looking to replace this part, I think its leaking, or at least sounds like it, any ideas where i can find a replacement part?
John Trigg
    Sergeant:
  • 250 Answers
WHEN THE ENGINE IS COLD put your hand on the muffler. Where the exhaust comes out is the rear of the muffler. Now go to the front of the muffler. The pipe that goes in is the one you are looking for. Keep following that pipe along until it joins the body of the motor, and you have found what you are looking for. Please rate this answer.
Posted on Sep 17, 2011
Last time. I have Ford focus 2003 sedan dohc 2L. I lost a part from exhaust system. from back to front I see 1. tail pipe 2. rectangular box shaped part? Lunch Box? 3. missing part Muffler?
Starting from the front, coming off the exhaust manifold should have, 1. Exhaust pipe, 2. Catalytic converter, 3. Exhaust pipe, 4. Resonator, 5. Tail pipe. Also, there should be an Oxygen sensor somewhere around the catalytic converter.
Jul 02, 2017 | Ford Cars & Trucks
My car sounds like a airplane when it idles up
-Possible broken exhaust gasket. depend on where the sounds came from...?
Good luck
Mai
May 20, 2014 | 2001 Ford Focus
I have an exhaust leak in my 98 ford ranger 3.0 auto long bed that I can not seems to solve. I have replaced the exhaust manifold gaskets, egr tube, and the muffler which all were leaking. I have taken...
Have a smoke machine used on the exhaust system
If your not familiar with one,they were designed for finding EVAP Leaks,and can be used for lots of things.
A muffer shop with no smoke. That is Fired Flintstone Repair
Oct 07, 2010 | 2008 Ford Ranger 2WD
How is the manifold removed on 2005 lincoln ls? Where is the bolt that holding it down?
Exhaust Manifold - Removal & Installation3.0L Engine
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Remove or disconnect the following:
    Negative battery cable Heat shields Lower splash shields Exhaust front pipes Secondary air tubes Exhaust Gas Recirculation (EGR) tube Exhaust manifold
To install:
Fig. Right exhaust manifold torque sequence-3.0L engine
Fig. Left exhaust manifold torque sequence-3.0L engine
  1. Install the exhaust manifolds. Tighten the fasteners in sequence as follows:
    1. Step 1: 15 ft. lbs. (20 Nm)
    2. Step 2: 15 ft. lbs. (20 Nm)
  2. Install or connect the following:
    Exhaust Gas Recirculation (EGR) tube Secondary air tubes Exhaust front pipes Lower splash shields Heat shields Negative battery cable
  3. Start the engine and check for leaks.
continue...
Jun 21, 2010 | 2002 Lincoln LS
Loud muffler sound is it the muffler
It can be the muffler. Also the Catalytic converter or just a gasket connecting the exhaust manifold to the pipes.
This needs to be inspected because fumes can kill. The entire system is meant to get the fumes to the back bumper through the pipes.
May 21, 2010 | 1996 Ford Windstar
How to change an exhaust manifold leak 7.5L
Right-Hand
Removal
  1. Remove spark plug heat shield (12A406).
  1. Remove distributor to spark plug wires (12286) using Spark Plug Wire Remover T74P-6666-A.
    1. Disconnect muffler inlet pipe.
    1. If equipped with secondary air injection, disconnect the secondary air injection check valve tube (9B480).
    1. Remove attaching bolts and right exhaust manifold (9430).
    1. Inspect joint faces for signs fo exhaust leaks, cracks or any defect that would make exhaust manifold unfit for use
Left-Hand Removal
1. Remove oil level indicator tube (6754).
  1. Remove spark plug heat shield.
  1. Remove distributor to spark plug wires using Spark Plug Wire Remover T74P-6666-A.
  1. Disconnect EGR valve to exhaust manifold tube (9D477). If equipped with air injection, disconnect the secondary air injection check valve tube.
  1. Remove attaching bolts and exhaust manifold (9431).
  1. Inspect joint faces for signs of exhaust leaks, cracks or any defect that would make the exhaust manifold unfit for use.
Installation
  1. Clean mating surfaces of right exhaust manifold or left exhaust manifold and cylinder head (6049). Clean mounting flange of right exhaust manifold or left exhaust manifold and inlet pipe(s). Clean mounting surface for air injection tube or right exhaust manifold. Apply light film of Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B to right exhaust manifold or left exhaust manifold.
  1. Position right exhaust manifold or left exhaust manifold on cylinder head. Install attaching bolts and washers, starting at fourth bolt hole from front of each right exhaust manifold or left exhaust manifold. Tighten bolts to 34-47 Nm (25-35 lb-ft), working from center right to both ends.
    1. Position inlet pipes to right exhaust manifold or left exhaust manifold. Install attaching nuts and tighten to 34-47 Nm (25-35 lb-ft).
    1. Position the secondary air injection check valve tube and the secondary air injection tube gasket (9C435) at rear of right-hand exhaust manifold. Install attaching bolts and tighten to 19-25 Nm (14-18 lb-ft).
    1. Attach the secondary air injection manifold tube (9B449) to left-hand exhaust manifold fitting (located under EGR tube). Tighten nut to 30-40 Nm (22-30 lb-ft).
    1. Attach the secondary air injection check valve tube to rear of right-hand cylinder head. Tighten bolts to 75-85 Nm (56-62 lb-ft).
      1. Connect EGR valve to exhaust manifold tube to left exhaust manifold, if removed. Tighten nut to 53-72 Nm (39-53 lb-ft).
      1. Install spark plug heat shield and distributor to spark plug wires.
      1. Install oil level indicator tube to left exhaust manifold, if removed. Tighten nut to 13-24 Nm (10-18 lb-ft).
      2. Start engine (6007) and check for exhaust leaks.
Hope this helps you...WF †
Mar 10, 2010 | 1996 Ford F250 Crew Cab
I have a strong exhaust smell- a put-put noise coming from under the hood- took to muffler guy, not the muffler
most likely (since it is not the muffler) is the donut where the ezhaust pipe hooks onto the exaust manifold....or the manifold cracked or needing a new gasket
Feb 25, 2010 | 2004 Mazda 6
I have 96 Caprice Classic...muffler has begun making quite a throaty rumble...I took to Monro Muffler...they said I need to replace from Manifold all the way to back....they want some $600. Anybody have...
I can't see your exhaust system, but I do recommend that you have them show you the "why" of it. Generally the front pipe and the cat last a long time and generally don't need to be replaced very often. If the flanges are rusted and have failed there are "wrap around" replacements that can be used without pipe replacement. Most common is to change everything from the cat back. As I said, have them actually show you what is wrong...or take it to another shop and without telling them the original findings, have them look at it!!! Since there is very little involved except a visual inspection, most shops will not charge or will charge very little for this.
Oct 21, 2009 | 1996 Chevrolet Caprice
I need to replace the oil pan gasket and it looks like the exhaust pipe is in the way-what should I do?
The tail pipe is connected to the muffler. You need to remove the entire muffler. However, the hot exhaust fumes tend to corrode connections so taking off the muffler might require some work.
Jul 02, 2009 | Toyota Camry Cars & Trucks
Loud muffler noise up front of vehical.what is
If the noise sounds like your muffler, but isn't coming from the area of your muffler, then you have an exhaust leak upstream from the muffler.
From the front of your muffler, follow the tubing forward to the catalytic converter, then forward to the engine exhaust manifold.
If you start with the car sitting for a few hours to make sure it's cold, you can use your hand to feel for blowing leaks while the engine is running, but chances are you'll be able to hear it. be careful of the catalytic converter itself, as it heats up fast, so check that first.
Once you've found the leak, the fix depends on the emissions laws in your state. If you have none, and the leak is in the middle of the pipe, you can buy pipe patchers (metal preferred) through auto parts stores or catalogs/websites. If you have strict emissions laws, or the leak is at the junction of the catalytic converter and pipe, you'll need to replace the failing part.
Jun 26, 2009 | 1993 Toyota Camry V6
Generac Guardian Ultra Source 15,000 Watt Portable Generator #04582 Logo
125 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
Marvin
Marvin
epangan29
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
