Question about Brother HL-4070CDW Printer
Hi. When we print color pages, on our HL-4070CDW, there are colors on the edges of the paper...usually on the right side of the paper. Sometimes it's yellow or red, etc. How do I resolve this?
Posted by jaslc on
Anonymous
    New Friend:
You need to clean your corona wires. Go to Brother support website. Look for Problem 100000012419 and follow steps in solution 200000015852.
Posted on Oct 27, 2011
How to repair or replace the drum on "Brother HL-4070CDW" Printer
You can reset the drum count, it will only affect your prints as the drum wears out. If the quality is still good, you can just keep on printing, but will eventually have to replace it.
Reset:
  1. Turn on the Printer's Power. ...
  2. Select "Machine Info" by pressing "+" or "-" keys on the top front "Control Panel".
  3. Press "OK".
  4. Select "Reset Parts LIfe" by pressing "+" or "-" keys on the top front "Control Panel".
  5. Press "OK".
When printing in color the right edge of paper is smuged
Inks from your printhead is deposited on right side of the soft sponge across the printhead pathway. Take a tissue paper and fold it and gently dap it dry
Some places does not print
you have a printer driver in pc
Hi I'm getting pink images from a Brother HL-4070CDW. I've tried recalibration and setting the colors adjustments in printing preferences, but that didn't change anything. Straight black prints fine. The...
It could be a problem with the bias voltages in the High Voltage Power Supply, but a much more common cause is simply a bad magenta toner cartridge. If the cartridge is fairly new, take it and a print sample back to the store where you bought it, and they might exchange it for you.
We have red and yellow ink at the edge of the right side of paper is there anything we can do about this?
can't solve it, but i find it interesting that i typed
MY PRINTED PAGES HAVE RED INK ON THE EDGE
and my printer model came up in the search as the first result!
looks like this is a common problem!!!
1helpful
Hl-4070cdw prints booklets with upside down pages
I had the same problem and finally figured it out.
When you select print and the print window comes up:
select Printing Preferences or Properties (depends on program you are using),
select the Advance tab,
select the icon that has 'A' and 'B' on two pages (near the top left),
select Booklet Printing. (then Okay and Okay/Print, depends on program)
In all honesty, I'm can't remember if this is what I selected to fix the problem, but the choice is on this page. Try this with each choice of "Flip on Left Edge" and then "Flip on Right Edge".
If neither works, unselect Booklet Printing and try "Flip on Top Edge" and if that doesn't work, try "Flip on Bottom Edge". Etc.
I know the solution is on this screen so experiment until you find it.
Good Luck!
Can the hl-4040cn laser printer copy docuement or just print
Hello my friends try to read this please: This printer can only print document files, pictures and etc. but cannot scan a document file. Additional input:
Strengths: fast speed, low cost per page and for the printer, reprint feature, good text quality
Weaknesses: setup is annoying if you don't know IP addresses, heavy, only ok picture quality
For this color laser printer, a sometimes-awkward design offsets good pricing, speed, and print quality. Brother takes a major evolutionary step with the HL-4040CN: This is the first color laser designed by the company itself, rather than a rebranded model from another manufacturer. It's a decent first effort, offering good overall speed and print quality for a competitive price. The design sometimes falls short on ease of use, unfortunately.
The setup process is easy and thoroughly documented in a printed guide as well as in animated videos on the included CD. Find a buddy to help you lift the printer, though: At about 63.7 pounds (according to Brother's specs), it's heavier than most comparably equipped color lasers.
At default settings the HL-4040CN printed competently. Its speeds--average overall--ranged from 19.3 pages per minute for plain black text to 4.2 ppm for graphics. Text in all tested fonts looked perfectly crisp. Color images erred on the yellow side; photos looked grainy, especially on glossy laser paper. Using the driver's "Fine (2400 dpi class)" setting improved images noticeably.
Brother deserves kudos for its software, which includes a comprehensive, well-illustrated user guide (in HTML and PDF) and interactive help files, as well as a dynamic status monitor. The driver offers a good supply of printing options.
The hardware, on the other hand, needs work. The control panel's LCD is great, as it can tilt 0 to 90 degrees, glows green when things are normal and red when things go awry, and communicates in plain English. But the menu buttons didn't always make sense to me: The up-arrow/plus button is for scrolling backward and the down-arrow/minus is for scrolling forward, while the "Go" button is also for pausing. The 50-sheet multipurpose tray is unmarked and hard to find (it folds out from the front of the printer).
Most odd, the toner cartridge bays are not keyed to prevent insertion of the wrong color. Brother says that such a mistake will not damage the printer, and it didn't when I intentionally switched two colors. But the printer should, at least, have recognized the mistake at the start and refused to print. Instead it printed a bizarrely colored page.
Cost per page (based on Brother's specs) is very good. The high-yield cartridges have a page capacity of 5000 for black and 4000 for each color and cost $93 and $130, respectively. A half-page of black text, therefore, will cost less than 2 cents' worth of toner to print, and a color page (using a small amount of black plus all three colors) will cost less than 12 cents. Standard-capacity cartridges with shorter page lives (and thus higher costs) are also available.
The HL-4040CN is designed to be, and is priced as, a low-end machine. Shoppers seeking more features (such as additional paper capacity) might consider its higher-end cousin, the HL-4070CDW.
Melissa Riofrio
Or you can browse this site:  http://www.pcworld.com/reviews/product/30162/overview/hl4040cn.html
Hope thisinfo helps in you.
If you need more assistance just conatc me.
Thanks
Color spots on left margin when printing with my HL-4070CDW
Replace the cartridge if that dont do it its the write head fouled up with ink or just plain died all togeather, dried ink can cause this to happen check and see if you can clean it out with 70 percent isp. alcohal if the issue still does not resolve its new printer time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Brother HL-4070CDW Printer Logo
Ekse
k24674
