SOURCE: hi I have a honywell termostat
Press and hold at the same time the two buttons: FAN (bottom middle) and UP (top right) for a few seconds until the display changes and there is a 1 and 0? displayed...
the 1, the larger number on the left, is the "function" and the smaller number on the right is the "setting"...
Press below NEXT until you get to "function" 14 and then use arrows to change the "setting" from 0 aka `F... to 1 aka `C... press below DONE to finish.
Otherwise google TH6110D manual
SOURCE: how to unlock voltas vertis
if your remote get locked then simultaneously press your temperature up down keys for some time ....lock will be opened .
SOURCE: Hi All, My Voltas Split AC
in the pcb board there is a switch called manual switch it will on ur unit just open the indoor flap.
SOURCE: How do I change my
try to inspect your remote it has a button of adjusting farenheit to celcius or try to see your users manual.
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
