Question about Microsoft Windows XP Home Edition
My pc says"boot failure,insert boot diskette in A"
Posted by merdenic64 on
Marc William Denis
    New Friend:
  • 66 Answers
If XP was not installed on the HD from your computer then the computer won't boot from it. Reinstall it.
The system may not see your HD. As you boot, go to the boot menu and see if the HD is listed. - If it's not, see if the HD is well connected to the motherboard. - If it is then re install XP.
Posted on Sep 16, 2011
Floppy diskette seek failure
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
A used dell computer, hooked it up and black screen comes up and it says diskette 1 seek failure
Below is a list of possible causes.
Faulty or improperly inserted diskette, incorrect configuration settings in System Setup program(You might be set to boot from the floppy drive. You want to be set to boot from the hard drive), loose diskette/tape drive interface cable, or loose power cable.
If possible please rate this solution.
Aug 26, 2010 | Dell Dimension 8250 PC Desktop
Diskette Drive Failure for Dimension C521
Most C521's have no floppy, if you have none:
boot to the BIOS, (F2 at boot) go to the drives setting, diskette (May be listed as floppy disk drive) set to NONE, exit and save settings
Apr 10, 2010 | Dell Dimension C521 PC Desktop
Dell logo appears and message appears INSERT BOOT DISKETTE...
A couple of things can cause this.
1] having the 'boot order' set up so that the computer looks to a removable device that has non-bootable media in it.
2] somehow the 'boot' device has lost it's 'boot' properties.
Best way to troubleshoot:
1] find the boot CD
2] re-strat the machine and enter the "BIOS setup" mode <f10>, or <DEL>; I think::verify the boot order
this should likely be: C: ; CD ; A:
allow machine to start with CD and check to see if anything on the wanted 'boot' device has been lost; sometimes it will get smashed.
Let us know what you get after this point, because I would rather give you an answer based on knowledge from this part of the exercise.
Mar 21, 2009 | Dell Dimension 4100 (-JM0TB01) PC Desktop
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Nov 22, 2008 | Dell Dimension C521 PC Desktop
Invalid Boot Diskette
Check the floppy drive to see if there is a disk in it....if so, remove it and try booting up the computer again.
Jan 20, 2008 | Dell Dimension 2300 PC Desktop
Microsoft Windows XP Home Edition Logo
155 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
