Cameras Logo
Question about Cameras
Where is the reset button of Kodak M1033 - Cameras
Posted by monettecport on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
There is no reset button as such. You can reset the camera to its default settings by using the "Reset" command in the Setup menu.
Press the Menu button. Use cursor-left/right to select the Settings tab. Use cursor-up/down to select "Reset Camera" (fourth from the end) and press the OK button.
Posted on Sep 16, 2011
  • monettecport Sep 18, 2011
    so it means i can't reset it anymore. because only the power button is working the rest are not
I have a Kodak Easyshare M1033. When I try to use the zoom it turns the camera off.
Have you tried doing a reset ? The instructions for this should be in the manual.
1helpful
I have a Kodak Easyshare M1033. When my camera turns on it wants the date and time set and none of the buttons work!
HELLO SIR
turn it on , Press Reset Buttonù
turn it off , still pressing The switch on button 10 seconds
It works for me
How do i delete pictures on my Kodak M1033
Heidi, to delete the pictures on your camera you need to press the review button on your camera, the review button is like an icon of a triangle. Now if you pictur is already displayed on your screen you just need to press the delete button or the trash bin button.
1helpful
Kodak M1033 operatin manuel -how to operate camera
http://support.en.kodak.com/app/answers/detail/a_id/18915/kw/m1033
Kodak M1033 Videos volume is very very low when I playback on my camera. When I playback the files on my PC there is absolutely no volume at all.
You might be blocking the microphone when recording.
Unfortunantly there is no volume adjustment button on the model.
1helpful
2answers
Faulty playback after transfer to PC - Kodak M1033
1. Try playing the same vedio in camera itself. If it plays well then there is no problem in camera and also in capturing.
2. If playback is problem in camera itself, then try resetting the camera back to factory setting.
3. If problem is not with your camera, then try playing those vedio in players like klmegacodec or VLC player. Because most of the vedios captured in camera or mobile phone finds difficult to played on normal media players in system.
Kodak M1033 turns on but basically freezes up.
check you power on switch, mine had the same problems as yours, kodak didnt help much but i checked the power switch and it was jammed a little so unjammed it an lo and behold fixed it saved myslef a lot of time.
Top Cameras Experts
Steve
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
