SOURCE: HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
SOURCE: 59 C0 error on hp color laserjet 5550
I had the same error, I had to take the left side cover off, (looking at the front of the machine) and found a small piece of paper that ended up right in the middle of a sensor flag! Of ALL the places to land. I pulled it out, it worked, end of problem! When you get the side cover off, the sensor flag is located in the middle/bottom of the printer. Hope this helps, happy fixin'.
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
