Question about Boss AUDIO SYSTEMS BV9455 Car DVD Player
Hi, I have a bv9962 and lost the wire harness plug, the one with all the speaker wires coming out. It is a 14 prong plug that plugs in next to the power and ground wires. A color code diagram from left to right and top to bottom would save me a ton of time. Thank you for your time and help and have a GREAT week!!
Posted by rrfdimeg on
1 Related Answer
Anonymous
  • 2047 Answers
SOURCE: BOSS 7300 in dash DVD
The flicker which happens is as a result of a power failure in the unit. Whenever this power fluctuation occurs it causes the unit power to go off and then restart. The restart is what brings about the screen which displays media at the top and the radio display screen. try tracing the cables which supply power to the unit for any inconsistencies to sort this out. Also you can check te use which affects the supply of power to te unit.
Here are 2 links to help with bypassing the brake. The first is a video while the other is a detailed step by step explanation.
http://www.youtube.com/watch?v=NgdfLst2QvQ
http://www.ehow.com/how_7265002_bypass-brake-wire-dvd-player.html
hope this solution has been helpful?
Posted on Mar 27, 2011
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
2answers
2006 Mitsubishi galant, I am TRYING to wire an aftermarket radio, can someone please help me and tell me what wires are which and why is there 2 plugs? Lil plug has red, black, brown, and white wires, and...
did you buy a wiring harness because all aftermarket radios have different wiring so if you buy a wiring harness it should plug in so you're already stationary wires that you have in this pictureand that harness should plug into the wires that you already have with the radio you have to get a wiring harness for your make and model vehicle if you don't have one already
I have a 2001 CRV. The replacement alternator has 4 prong plug. The one on the car has a green 3 prong plug?
Here's the problem:
http://honda-tech.com/showthread.php?t=2624894
Sounds like you have a Canadian SiR harness (all Candian 6th gen civics use a 3 wire alternator plug instead of the USDM 4 wire setup, IIRC its because the Canadian civics don't have an ELD) easiest thing to do in this situation is to reuse the original SiR alternator.
Don't know where you live or where you bought the vehicle but it's Canadian. Next time you need parts be sure and tell your supplier that it needs Canadian parts.
3helpful
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
I have a JVC head unit for my car its the 720 unit anyways i have bought to wiring harness for my 2005 gmc sierra slt and the one it powers on but no sound comes out this is made by pac the other one is...
if you keep guessing you are going to fry the head unit.there is 3 plug ins on most wiring harnesses,they are made for two fit different yr gm cars.one plug for power supply and a second for speakers the 3rd is not used.they will only plug in one way.speakers should be wired the speaker wire,one has a line on it ,use that wire on each speaker for ground and the solid colored wire it a plus or poss.wire,on each speaker the same way.also make sure the head unit is grounded good.take your time the harness comes with the instructions.follow them to a T.i have a feeling that the wiring is not being matched up right.it is not in the harness your buying.triple check all wiring connections.hope it helps.PS IF YOU CAN SMELL ANY BURNT SMELL COMING FROM REAR OF HEAD UNIT ITS COOKED.HOPE I COULD HELP.
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
1helpful
On my 1990 Ford Bronco the trailer harness adapter does not work when plugged into the factory wiring at the rear bumper. I have tried a new adapter and the result is the same. I have checked for voltage...
I assume you are getting power at the plug. If not, first check to be sure you have a good ground at the plug harness. White wire. You can ground it to the frame. If so, check the ground on the trailer. With 2 wire lights you can ground to the frame. 3 wire lights require a ground to each light. Also try http://www.etrailer.com/faq-wiring.aspx. On my old 1990 ford truck it had fused links at the harness under the hood next to the battery.
My name is Noah. I have a Volfenhag zx 7150 2 channel amp, and I was wondering if I could use this amp to run my mids and highs. And if yes, how would I run the wiring?
Hello violentj_1_u,
Yes, the amp can be used to power normal speakers on 2 channels.
The best way to wire the amp to a stock receiver (head unit) is to use a pair of wiring harnesses, one the standard harness that plugs into the vehicle wiring, the other a "reverse" harness that plugs into the stock receiver.
First remove the plug from the receiver and plug in the "reverse" harness. Run the speaker leads from the reverse harness to your amp inputs or to a line output converter (LOC) and RCA's to the amp. Then run the amp speaker outputs to the standard harness speaker wires. Plug the original receiver plug into the standard harness and splice the remaining wires, 12V constant, 12V accessory, ground, illumination, etc, together. Connect the 12V switched wire to your amp remote terminal.
Hope this helps.
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Good luck
Aduz
2answers
I have a 3-prong plug on a 14-year-old dryer. Now must change to 4-plug. Is that possible ... and if so, how?
A three Prong contains L1 (Line1), L2 (Line2) and N (Neutral). A four prong will contain L1 (Line1), L2 (Line2), N (Neutral) and G (Ground) typically a green wire.
Connect the three wires as normal, connect the green wire to the screw provided on the cabinet.
Jul 04, 2008 • Dryers
Boss AUDIO SYSTEMS BV9455 Car DVD Player Logo
Top Boss Car Audio & Video Experts
xxxxxx xxx
ENFORCER
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
