Question about Welding Tools
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes
1. Torch switch is activated (closed) before user turns power on.
a. Release torch switch.
2. Faulty torch switch
a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON
1. System is in SET mode
a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Posted on Sep 16, 2011
Dec 18, 2014 | Thermal Dynamics CUTMASTER 81 Air Plasma...
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Jul 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Jun 23, 2011 | Miller Welding Tools
Jun 21, 2011 | Welding Tools
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
Dec 07, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
May 16, 2009 | Welding Tools
Sep 27, 2008 | Welding Tools
1,288 people viewed this question
