Question about Mindscape PrintMaster Premier 7.0
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster and it give me an error message to contact mindscape. I have tried and have had no response. Could you please help me get this program up an running. Thank you, Cyndi
Posted by Cyndi McNeil on
  • LSKk
    LSKk Jul 21, 2015
    It will work on Win 7 by starting 'XPmode Virtual PC' .. If you have Win7 pro and above you can install the program running in Virtual XP mode; If you have win 7 home premium and below you will have to install virtual xp and Winxp mode by downloading them from the Microsoft download site.. You can search Google for info on how to install Virtual PC and Win xp mode on Win 7 home premium.. I installed it on my Win 7 Pro 64 bit computer and it runs great.
LSKk
    New Friend:
Posted on Jul 21, 2015
Wale Sarumi KomputerSolution
  • 6,993 Answers
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Posted on Sep 15, 2011
I have PrintMaster Premier 8.0, I would like to install on my computer running windows 7. It will not download. I do not want to purchase another version. Is there any updates that I can download to allow...
1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
Sep 11, 2013 | Mindscape PrintMaster Premier 7.0
LOOKING for the old yellow trifold Printmaster Platinum Program, Art and Photos CDs. It has an address-birthday anniversary list that I can't find in the later versions'. I bought two, one is...
Based on your question, I am assuming you are looking to purchase this from anywhere you can find it. Amazon.com has it:
http://www.amazon.com/Mindscape-112947-Printmaster-Premier-7-0/dp/B00003IE80
If purchasing another copy was not your intent, reply to this answer and let me know what you need. I hope this helps you!
Sep 25, 2011 | Mindscape PrintMaster Premier 7.0
I bought a new computer with windows 7, have older version of printmaster permier 8.0 and it will not install. help
Hi lavernhess
There is no direct solution to this issue since there is no driver running under Windows 7 for your product .
You could install a virtual version of XP on your machine with http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft's if you are using Integral or Professional .
Otherwise , you will need to purchase a recent version of Printmaster compatible with W 7 , if available .
Best regards ,
fanaudi .
Aug 24, 2011 | The Learning Company PrintMaster Premier...
Our business has been using Printmaster 15 for a few years now. We recently bought a new computer with windows 7. Printmaster 15 is obviously not compatible with Windows 7. I bought printmaster 2011...
You can try version 15 in compatibility mode:
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows:
Jul 19, 2017 | Broderbund PrintMaster Platinum 16
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
I am using an old (but good) Printmaster Platinum 11 and would like to update. A few years ago I got a detective Gold 18 which I cannot use. I have Windows XP Home and am being told that I must update my...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Nov 18, 2010 | Broderbund PrintMaster Platinum
Is there a way I can use my Printmaster premier 7.0 on my new computer with Vista?
you need to register your product Once you register your program PrintMaster will send you information about additional upgrades. All of which are affordable.
Dec 06, 2009 | Mindscape PrintMaster Premier 7.0
Printmaster and Windows Vista
been running printmaster platinum 8.0 for many years on several different computers . have had it installed and running on my HPPavilion slimline for two years now . problem is that i cant get it too print anything new that i create it will print out older stuff that i have created but nothing new . have checked drivers on print they are all up to snuff , and have uninstalled and reinstalled both the printer and the printmaster program but still cant get it too print anything new that i create . it does print everything else in the PM program. and otherwheres on my computer
Feb 09, 2008 | Broderbund PrintMaster Platinum 16
Mindscape PrintMaster Premier 7.0 Logo
334 people viewed this question
Top Mindscape Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Mindscape Computer and Internet Expert? Answer questions, earn points and help others
