SOURCE: Vulcan A1990 Model 60XL;
You need to replace the thermocouple for both sides of the oven. That is the most common issue with pilot lights and gas burners. The safety shut off will engage when it does not sense any heat, ie: thermocouples.
SOURCE: when trying to light my oven, it take more than 5
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: I just installed a new bertazzoni and somehow when
Hello Mike,
The problem seems to be your thermal-couple safety valve. As when the valve does not get enough heat or has gone bad you have to replace it as the burner will not keep the flame going. If it is newer than two years it should still be under warranty and Bertozzoni will repair by calling 866 905 0010.
However, if it is older than two years there are five therma-couples on this Range I will need to know exactly which burners are working and which are not as to find out the part numbers.
Thank you for chosen FIxya.com
Justin
