Question about GE 30 in. JGP337 Gas Cooktop
MI ESTUFA TIENE UN PROBLEMA QUE LOS QUEMADORE PEQUENO FUNCIONA POR UNOS 3 MINUTO Y LUEGO ESPLOTA Y SE APAGAN, PERO EL QUEMADOR GRANDE SIGE ENSENDIDO, EL MODELO JG337 ,, 183D8998G002 YO LA LIMPIE Y AJUSTE LOS QUEMADORE PERO SIGE IGUAL SOLOS SON LOS PEQUENO EL DERECHA GRANDE NO TIENE PROBLEMA ESTO PASO CUANDO LE CANBIE EL SILINDRO DE QUE EMPESO A DARME ESTE PROBLEMA
Posted by jesus7364 on
Just installed replacement glass top (from GE,original) and get Codes SE on the timer touchpoint.
That error comes from the touchpad, if it got wet, something boiled over on it, it is shorted etc.
May 07, 2016 | GE Profile 36" Electric Induction Cooktop...
Would like to pick-up appliance part local Los Angeles,CA.
http://www.dacor.com/customer-care/locate-a-servicer.aspx
Paul go with the authorised dealers from the link above put in your post code and search
Sep 16, 2014 | Dacor Cooktops
How do i repair or purchase a bent wok burnerhead
Excessive heat is a problem with wok burners, pretty difficult to get them properly flat,you need to buy a new burner. They are pretty easy to fit.
Mar 13, 2014 | Cooktops
Hi I have a Samsung ceramic hob that when I have the oven on and cooking veg in saucepans it cuts out randomly displaying SE flashing I'm guessing its overheating but how can I fix this ? It makes
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
  • Touching the key area for more than 10 seconds.
  • Leaving a wet cloth on the touch key area.
  • Spilling a liquid on the key area.
  • By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Jan 30, 2018 | Cooktops
How do I remove my electric cooktop...the conduit enter thru an L connector into the cooktop and prevents it from being lifted out...I cannot figure out how to get under the control knobs to access the...
On link below is a install manual It might not be yours but they are all pretty much the same. It will tell you how to install. You just do the reverse to remove.
Also you do not un wire the cooktop from the cooktop but from the junction box in the wall. Please make sure the breaker is turned off before you un-wire it.
http://www.jennair.com/assets/product/JEI0430ADS_Installation%20Instruction_EN.pdf
Apr 17, 2010 | Jenn-Air Cooktops
Our two burners on the right are not igniting, can you tell us why? how do I fix it ? the two on the left are fine.
judging by your post I can only assume that the range is gas. If so then the left and right side are controlled by two separate ig-niter boxes and one of them have failed. In order to repair it you will need to locate the ignition module's. They are usually located under the plate that houses the knob assembly. To determine witch one it is you will need to un plug the range and disconnect only one of the burners. Plug back in the range and try to fire one of the burners that works and see if it is not working now. If it is then you have un plugged the correct one. Again un plug the range and finish the removal. Sense this is Jenn-air then you will need to order the new one from them. Hope this helps. Good luck.
Dec 02, 2009 | Jenn-Air Cooktops
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Converting stovetop from natural gas to lp
there is a square nut on top of the regulator un screw it and underneath you will find a Cly flip that over should take care of it one side will say ( nat) the other will say( lp) you want lp up
Feb 25, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
GE 30 in. JGP337 Gas Cooktop Logo
200 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
