Check the fuel lines going to the carb. from the fuel tank for leaks and replace if they are bad.
lines ok seems like tank may be leaking
try taking the carb. apart and clean the screen and needle valve and idle and air mix screws in it, if dirt is in the needle valve , it may cause fuel to leak on to the tank from the air filter side of the carb. making it look like the tank is leaking. Blow the carb. out with an air compressor to clean.
it was the fuel vent tube had lost the little white plug on the end
thx for the help
That was what I was going to have you to check next, gald you got it fixed.
