How do I get my carpet shampooer to spray wate
If your machine was designed to spray hot water, detergent cleaner or a combination of both, chances are the filter/strainer inside the reservoir may have become clogged, the feed tube may be twisted and pinched closed or the spray nozzle may be clogged from various contaminants. Try and get a look down inside the container where you fill it with fluids and see what you can determine, also check the spray tip or nozzle where the fluids are supposed to be expelled for a clog. If the small service pump is the culprit, servicing or replacing the pump will be a bit more involved and parts are available from most manufacturers websites these days. Hope this is helpful :)
