Question about Stanley Garden
Does not fire when hot - Stanley Garden
Posted by digslogs on
paul nielsen
  • 252 Answers
Hi thre digslogs
pull the kill wire from ignition coil if a cdi type ignition unit and see if spark when hot , if not faulty coil indicated replace coil and set air gap
cheers take look
pauly46
Posted on Sep 15, 2011
Why does fire burn u
Because its hot. Not only will fire burn you but any material or object that is hot can burn you or cause scorching or smoke. An electrical charge can burn you. Leaning against a hot car in the heat of the sun can burn you. Very hot water can burn you. A iron left on can burn you. A stove top burner or oven can burn you. If it's hot, IT BURNS! !
Mar 25, 2015 | Cars & Trucks
Why is fire hot
Fire is a chemical reaction involving the burning substance and oxygen. The typical byproducts of such reactions are ash, heat, and light. It is this heat that makes most fires hot.
See http://en.wikipedia.org/wiki/Fire
Aug 01, 2013 | Computers & Internet
Rear cylinder does not fire 1987 FLHTC
If you're getting fire, but the cylinder isn't getting hot (I always check the exhaust pipe near where it exits the head), possibly you're not getting air/fuel mixture to that cylinder.
Is the intake valve opening?
Check valve adjustment?
Apr 09, 2013 | Harley Davidson Motorcycles
Kenmore gas dryer not getting hot enough to dry
If inside of drum gets hot suspect first somewhere between it and the place where it vents outside a blockage---Lint can do this and be hard to find and also represents a fire hazard, each year there are hundreds of fires caused by lint buildup that catches fire
Dec 09, 2012 | Dryers
Catilitic converter red hot now car wont start after its cooled 1996 cavilier
You should never drive a car with a red hot catalytic converter. If the catalytic converter is heater up to the point where it is that hot, it could be a serious fire hazard. Cars which might have a leak in a fuel line could be at a major risk for a fire or explosion if gas fumes come into contact with a catalytic converter in that condition. -----------------------------------------------------------------
Lexia-3 pp2000
Dec 06, 2012 | Cars & Trucks
When my truck is cold it starts fine when it gets
check ignition coil for fire when it is hot using a inline tester to check for fire to plugs. if no fire then replace coil. hope this will help!!
Apr 04, 2010 | 2000 Dodge Ram 3500
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
The coals are perfect and hot, but the fire goes out before the f
With charcoal you light the coals and wait till they have turned white and the fire will have gone out by then but it will be very hot and will last an hour or more.
Jul 11, 2009 | Weber One Touch Silver Charcoal Grill
Vivitar 285 HV won't fire
If you know basic soldering, Open the old hot shoe from base
(4 screws).Note down the position of the wires.
Try to fire the flash with shorting two trigger wires,most ly it will fire.
If the springy contact is adjustable do it.If it is not repairable, you can get metal hot shoe from ebay easily.
Caution: metal hot shoe will short circuit 4 TTL contacts (on digital camera) ,so you need to put cello tape at bottom of hot shoe with only center hole.
Hope this solves.
May 12, 2009 | Vivitar 285HV Flash
Garden Logo
125 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
