This has been answered before on FIXYA. Use the manual search code. Press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light should come on), then hold down "Power" while aiming the remote at your TV. Hold it down until your tv powers off. Then it should be configured and working.It may take several seconds. Then check if it turns on again and if the channels are working.
SOURCE: Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
SOURCE: I have an antsig AP593
I'm not sure if any of the codes work! But if you want to try the codes again. Put your remote right in front of the point where your TV receives signal (i.e. where you see a light). I used method B - manual searching of the code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), about 1mm away kinda thing! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
SOURCE: Antsig AP593 Universal Remote Control Code for Sanyo LCD-40XR10F LCD TV
Hello
Try these codes.
004/ 013/ 049/ 108/ 110/ 180/ 209
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
BW-0392
6 in 1 Pre Programmed Remote Control DVD Pioneer codes:
0175 0185 0665
(source: http://www.antennawarehouse.com.au/remotemaster/tech%20support/Universal_Remote_Control_code_list.pdf)
To have a look at the universal code lists for other products, visit:
http://www.antennawarehouse.com.au/remotemaster/codes.php
(Skandia remote support site)
It is the closest I could get. Not sure if it will help at all. Give it a try.
