HP LaserJet 1020 Printer Logo
Anonymous Posted on Sep 15, 2011
HP LaserJet 1020 Printer when i turn on the printer, its no noise no turn , only the ready led ligth
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Sep 15, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
450712
Points
2591
Symtom look like fatal error, replace formatter anf check..
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
There is a problem with my leser jet 1020, when ever i am going print a document, paper is coming out but there is no print on it. so kindly tell me what is the exact problem and how to solve...
HP LaserJet 1022 cold reset procedure To cold reset the printer, perform the following steps:
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancel buttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison.
The printer is now reset and ready for use. Back to top HP LaserJet 1018 and 1020 cold reset procedure To cold reset the printer, perform the following:
  2. Power on the printer.
The printer is now reset and ready for use. NOTE: The HP LaserJet 1020 printer is completely initialized at power on. Essential printer information for the printer is stored in the driver software and downloaded to the printer with the print job.
1helpful
2answers
Installed driver program says installed properly when i hit print it doesnt do anything, went to printer set up it says printer is ready
Uninstall the driver. Then go to hp.com to get the driver from the web site, its free. If you are still having problems it could be the operating system, try hooking it up to another computer system.
Communication between PrintServer DP-301U and HP LaserJet 1020
Trying turning your printer off and then back on. It happens sometimes that the print server looses the printer.
Alex
www.CAS411.com
27helpful
12answers
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
Printer problem in hp laser jet printer 1020
Problem is you have paper jam!!! Seek for the paper inside the printer, pull out cartridge!!! when you do that, turn off printer and disconnect power cable for 1min. Pull back the cable, turn printer ON!!!
good luck!!!
1020 laser printer problem
good luck!!!
k24674
Grand Canyon Tech
Grand Canyon Tech
