Question about Asko W600
I have an Asko W600 front load washer that does not spin water out of clothes. It fills, washes, empties but does not spin- skips this part.
Posted by oles2ndkid on
Daniel Scott
  • 4,323 Answers
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 15, 2011
Asko w600 front load washer did not spin water out of clothes. I emptied the drain pump and now it fills with water but doesnt wash the clothes. The water drains out but nothing else. Help
Check to see if your model has a "out of balance" micro switch.
If it's tripped from you moving the unit around you may have to reset it manually. It will be mounted somewhere close to the outer perimeter of the tub. Can't say exactly where. Could be high or low.
Jul 11, 2012 | Asko W600
Water Inlet Fault
check whether something is blocking the cycle.
Sep 19, 2008 | Asko W6461SS Front Load Washer
My ASKO W6222 won't drain
Sounds like the inlet water valve is not seated properly and is letting water in when it shouldn't .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 20, 2012 | Asko W6222 Top Load Washer
Need a part diagram or technical drawing for my asko w600 front loader. have cleared a blockage in the impeller that expells water so it fills and empties, but now it wont spin. Brushes i'm thinking?, can...
hello any spin problems can be down to the module board this control the motor speed this usually sits at the back of the of the washer may have a load of wires coming off it hope it helps
regards
shaun
Mar 19, 2011 | Washing Machines
Asko front loader, fill with water but won't wash, drains water OK
Hi, Have you removed the back panel to insure the belt is on ? What about the spin cycle, will it spin ? (That will also tell you the belt is good by the way) I'll watch for your reply. Regards, Macmarkus :)
Dec 09, 2010 | Asko W600
Washer not spinning properly
Hi, there may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out. Reconnect and try again.
Jul 13, 2010 | Asko W6021 Front Load Washer
My ASKO W600 slowly fills with water after it has completed the wash and spin cycle. The machine is 5 - 6 years old and runs perfectly otherwise. How is the water inlet controlled to the machine? Can there...
hi yes you need to replace the inlet valve you have dirt in it,remove the top panel you will see the triple valve.its very easy to replace,
Jun 06, 2010 | Asko W600
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Neptune washer tangles all cloths
the washer has a balance ring that hold water that is ok. as of the tangleing you may have a low water fill
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
258 people viewed this question
Top Asko Washing Machines Experts
Michael Thomas
Michael Thomas
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
