SOURCE: oven door won't unlock
kittyboy The first step I would recommend you to do is to turn the circuit breaker on, then set up the oven clock. Start the self clean for any amount of time, wait about 30 seconds and push the cancel button. Most of the time it helps to eliminate the problem. If it would not help, let me know and we will go further. In that case I will need the complete model number. If it is the free standing range, you can find it on the frame behind the bottom drawer. Gendos...post back
SOURCE: Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
SOURCE: Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
SOURCE: frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Thank you for your post, friend!
I see that you are having some challenges with your Frigidaire range. On your control panel if you have a "Clear" or "Cancel" button you can hold that down for five to ten seconds and it should release the latch. You can also hold down the light switch button on the oven door frame and the cancel button simultaneously for five to ten seconds to see if that would correct the problem. Last, I would perform a reset on your range which can be done by disconnecting power from the range for ten minutes. I hope this has been helpful. -Matt
