Question about Radio Communications
Trying to find the right size linear amp to hook up to my Galaxy dx 949. I want max in/outputs. tired of being talked over. I have a Golden Eagle 150w amp, but have not connected it
Posted by country_mp24 on
Laron
    Novelist:
  • 146 Answers
That linear will be good for 100 watts of clean power. It has two MRF455 transistor which are 60 watts a piece. The cb will drive it with the carrier or dead key reduced to about 1.5 to 2 watts but i suggest that you read the linear's power while adjusting dead key not exceeding the 100 watts pep with voice. An NPC mod would be a good addition to get the modulation up with a low dead key.
Before you start the projection make sure you antenna system is in good condition high SWR will smake you linear in a hurry.
In factory condition 949 galaxy with a 3.8 carrier it will drive a 667v TexasStar. It is a low drive linear that will end all disputes as to who has more power. 8 out of 10 birds that escape will die of cancer withiin 72 hrs. Ok could not help myself. I would not suggest that unless you just want to damage other peoples receive. The v is for variable power. Hope this was of help.
Posted on Sep 17, 2011
I have a galaxy 949 dx that won't talked side band
The antenna system is far better in your home base setup. All things being equal the earth ground will far improve your reception.
Apr 17, 2013 | Radio Communications
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Hi i have a galaxy dx 949 i loss the recevie what part do i change
Sub another mike becuse it is part of the circuit, audio output ic,"sometimes developes crack on case" check speaker,"opens" and finally check small capacitor near the audio output ic.
Mar 30, 2012 | Galaxy Radios DX-979 40-Channels Base CB...
Just got a Galaxy DX 2547. Barefoot works GREAT. Problem: When connecting to my linear (Texas Star 667V) rig fires up AOK on AM but on SSB it has issues driving the amp. SWR is OK Radio SSB output ~...
Have you tried turning the mic gain up,and not knowing Texas star model numbers,is it a mobile linear,if so,do you have a sufficient power supply?Just some thoughts off top of my head.
Aug 22, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Shows no modalation on meter when talking
the meter may be on the wrong setting or just may be blown out. Can friends still hear you talking when you are on the radio ?
Dec 08, 2010 | Galaxy Radios DX-949 40-Channels Base CB...
Need more talkpower without a linear amp
Send it to a CB shop and ask em to peak it and tune it,shouldnt cost more than 75.00
Apr 01, 2010 | Galaxy Radios DX- 88HL Base CB Radio
Galaxy 949 Receive problem
this sounds as the osolator has moved of freq. to check this you need to put it on a scope
Apr 14, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Galaxy 949 mobile CB is off frequency when
a friend of mine just told me he used the galaxy 2517 adjustment procedures. I hope this may help you. Buckeye back quiet.
Mar 03, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
It powers up....no modulation ...output power..or receive....just static...galaxy dx 949...
Sounds like the PLL may be toast. Either that, or someone has **** with the wrong potentiometers or tuning slugs in the radio, causing to to no longer resonate on the correct freqs.
Mar 02, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Radio Communications Logo
259 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
