Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
I have an 1285 tecnik cooker and over the years the the main oven elements have gone one by one starting with the fan element followed by the top element and then finally the base element. Anyway I have finally tracked down all 3 elements and have just replaced them all. Now I have the fan element working but the top and bottom elements are not heating up at all. I have also replaced the light bulb as well but it doesn't work either. Is there some internal fuse somewhere that is blown. Seems strange that only one of the three elements work and not the other two not mention the light bulb.
Posted by wasj on
4 Related Answers
Anonymous
SOURCE: I need the Manual for the Tecnik TKC 1285 Dual Fuel Kitchen
Tecnik appliances
2 Brindle Rd
Old Trafford
Manchester
M16 9HQ
Spares 08705543210
Service 08705678910
Posted on Feb 25, 2008
Anonymous
SOURCE: tecnik 1285
e-mail me at [email protected] and I will send you a copy either as a PDF or a publisher doc, please specify.
Dave H
Posted on Apr 14, 2008
odiebugs
odiebugs
  • 949 Answers
SOURCE: where can i buy a set of jets to convert to lpg a
From the manufacture of the appliance.
Contact Us Office Hours: 9am - 5:30pm Mon - Fri Trade Sales: 0161 786 4692 Appliance Care Service: 08705 678910 Spares: 08705 543210 Whirlpool Service Service & Spares: 0870 600 8989 Rangemaster Service Service & Spares: 0845 603 5312
Posted on Apr 09, 2009
Anonymous
SOURCE: TECNIK 1285 RANGE COOKER
I have a Tecnik Range cooke that was in the house when i bought it. The secong oven has no cover for the heating element at the top so everything I put in browns at the top. Should this oven have a metal plate underneath so that I can use it as a conventional oven or should it be like that
Posted on Mar 30, 2010
There is a loud buzzing from our Tecnik 1285 range cooker. The buzzing starts about 5 minutes after turning either of the ovens on, and only stops 10 minutes after turning it off. The front of the oven /...
its the cooling fan to keep the control and metal and top of cooker cool. mine is also extremely loud. I think it basically turns unecessarily quickly and could be slowed with a resistor in line
3helpful
2answers
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 • Ovens
2answers
Do you know the power rating of a TECNIK TKC 1255/SS cooker
i believe this is a range oven so has gas hob top one large oven a one small oven main oven draws around 2.5 kw on fan and 1.8 on conventional elements.
May 17, 2010 • Ovens
15helpful
2answers
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
12helpful
2answers
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Thanks.
Dec 15, 2008 • Smeg Ovens
Tecnik TKC 1285 back-plate
don't know technic products but suspect you just need a bit of bruto force - back plates can be stuck in with crud that accumulates
1helpful
Tecnik TKC 1285 Access to Fan Element
both. element is usually held by 2 7mm nuts on posts from element base plate which are accesible from rear plate. element comes out into the oven cavity
6helpful
10answers
Here is the site for Technik: http://www.tecnik.net/aftersales.htm Did you ever find the manual? Can I have a copy?!?
Kitchen Ranges Logo
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
