Question about Proton Televison & Video
My Proton TV loses it's color every so often. I've had the unit a long time. Was purchased from The Listening Room in Westchester County, NY Can it be fixed?
Posted by fdenicol on
Jdvillanueva
  • 2,098 Answers
Please let me know the model no. of your unit. Also, does the symptoms is the same to all inputs?
Jdvillanueva
Posted on Sep 14, 2011
Burning Glue Smell From LCD LG TV?
Your tV need service. Never swith ON this set as it is now. Contact the authorised service center for LG.
May 01, 2012 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
I have a small magnavox HDTV. I unplugged it to watch it in another room. The next day when I moved it back into the living room I turned it on. Every time I try changing the channel it changes the source...
Is it a multi-function remote? If it is, make sure you've punched the TV button before using it. Also, make sure none of the buttons on the remote or the TV have accidentally been pushed down and are stuck.
Jul 05, 2011 | Philips Televison & Video
Need McCulloch 100 series Eager ****** part # 92479 lever/handguard. Any retail store in Westchester County, NY where I can buy this part or any on-line?
Hi acf49,
Here is the web address for Milaca Lawn and Garden's online site:
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF
The McCulloch page will open for you. Click on "parts" tab above "McCulloch" and type in the part number. You'll have to click on your particular model number to see the parts diagram for your saw.
Or, you can go to http://www.mccullochpower.com/ and click on "service locator" and type in your city. I couldn't get the service locator to work for Westchester County, NY. Must need a city or zip. Give it a try!
Thanks for visiting fixya. com,
Handie Andie
Jun 12, 2011 | McCulloch Garden
What software can I purchase so I may make barcodes with a Voyager Honeywell scanner.
Microsoft Excel can print bar-code labels. I did this for my office for our stock room and they work with every bar-code reader I've used so far.
Apr 22, 2011 | Honeywell MS9540 Voyager Hand Held Scanner...
Remote for JT 290
good evening mr monds..,
you can purchase a new remote control for your proton jt 290 at the web address i posted below. they also list an alternative remote for the model.
http://remotes.com/store/proton/jt290.html
May 13, 2008 | Proton JT-290 TV
Canon pixma mp780 printing problem
If deep cleansing via software doesn't work then you've got to manually clean your print head unit. Sometimes you'll have to bite the bullet and get a replacement print-head unit ($$). If you're at the stage that you're considering replacement, then you've got nothing to lose by cleaning the print-head unit yourself. It's simple. Remove all ink cartridges first then remove the print head itself. Place the print head unit in a saucepan of warm (NOT boiling hot) water and leave to soak for an hour. (Protect your clothes - it gets messy) After an hour, flush the printhead unit under a running tap. Don't run the water too fast or you may damage the unit) You should flush until the water runs clear. Do not attempt to clear the nozzles with anything other than water - they are very fine needle jets and you will damage them!! If needs be, return to saucepan and leave to soak in warm water again and repeat process. When you are satisfied that the printhead is clean, you need to dry the unit thoroughly. Shake as much water from it as you can then pat it gently dry. Next place it on some absorbant kitchen paper and put the unit in a warm place to thoroughly dry (Overnight in a warm airing cupboard would be good). Once dry, refit the unit put in (Preferably new - but I've used existing one's without problem) cartridges and run a cleaning cycle. Your printer should now work as if new!!! - In Most cases!! - sometimes though, you'll either have to replace the print head unit - which sometimes can be more expensive that simply replacing the printer. What have you got to lose though eh? CLIVUSS
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Televison & Video Logo
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
