SOURCE: Turns on but doesn't Cook
Sounds like the Thermo safety limit has gone out. This goes out when the theromstat goes bad. There is no service done on this product. Call the company about getting a replacement while it is still under warranty.
SOURCE: No heat on brand new Waring WMK300 waffle maker
Lots of appliance makers include a 1 800 number with the paperwork that comes with an appliance.
I would try to find that number and call them. They owe you a replacement unit. If you can't find the number do a Google search for Waring and they should have a tel number and/or a "contact us" place to send and email.
Good luck Loringh
SOURCE: waffle mix spilled over entire waffle maker, inside and out
Is this question for real? If you can't figure this one out on your own, maybe you should stick to IHOP.
SOURCE: Star Waffle maker tripes gfi when plugged in
no , wet control board , you will need it to dry out for a day first . place near a heater outlet or in the sunlight for a day or two ..... should be fine ...... please rate this answer i need it to "get my wings"
SOURCE: waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
