Magicard Opera 100 Card Printer Logo
Posted on Sep 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello! I am writting this message regarding with my magiicard opera 100 that does not work. I am using it in school office right now to make student ID cards, however it is not working. The problem is that although I put my new color dye film, it does not work. The machine says to put a new dye film in order to print the card. Can you please fix my problem :c
Safe-Card ID Services
Level 2:
Novelist:
Scholar:
  • Expert 92 Answers
  • Posted on Nov 21, 2017
Expert
Level 2:
Novelist:
Scholar:
Answers
92
Questions
0
Helped
80862
Points
211
From your description, there are only a few possible causes:
1. The ribbon you have is not the correct one for your printer model, or is not a genuine Magicard ribbon. Where did you purchase?
2. The printer has old "firmware" that doesn't recognize new ribbon RFID tag info. (firmware is an internal program on the printer that should be periodically updated - free download from Magicard web-site: Magicard ID Card Printers Identity Solutions ).
3. The ribbon-sensor has failed (printer cannot see / sense the ribbon's presence).
If we can help further, just reach out to us!
Charlotte, NC USA
https://www.safecardid.com/
5 Related Answers
magicard
Magicard
  • 71 Answers
  • Posted on Aug 08, 2007
SOURCE: Mis-register
Hi There, 1. Make sure there is no dye film stuck to the print roller. This will cause card mis-registration (you will see feathered edges or a blurry effect. If there is dye film stuck to the print roller peel it off using adhesive tape or similar (the dye film will stick to the tape). You can move the print roller round with your finger quite easily. Then clean with a normal cleaning card. Afterwards check your print start and end position (you may be printing off the end of the card - also snaps the ribbon often!) 2. Make sure the other pinch rollers are really clean. 3. ** Check the warranty status first! *** Remove the right-hand side panel (2 screws on the side, 3 at the back). Check for free play on the card transport stepper motor pulley (there should be none!). Check the belt tension is not too loose (motor is adjustable - loosen 4 screws)). Hold the print roller with your left hand while trying to turn the large plastic pulley. You should feel no play. The grub screw on the pulley can sometimes come loose (1.5mm hex key required). Do NOT try to use a ball ended hex key. This only rounds off the grub screw socket. I hope the above helps! Regards, MC.
magicard
Magicard
  • 71 Answers
  • Posted on Jan 22, 2008
SOURCE: the cards are sticking
Hi There,
Im_useless:
0.126 is not a Magicard error number. On a Rio 2 printer, the error number will be displayed on the LCD display. It should look like 02:?? or 04:??, etc.
Are the cards feeding out of the hopper?
How far into the printer have they gone before you get the error?
Are any of the dye film panels printed before the card gets stuck?
Are the cards ejected when you click on 'OK'?
Guest:
The most common reason for the dye film sticking to the cards are if they already have overcoat printed on them (you can not print over overcoat). Also, if you are printing very dense images, try selecting 'ColorSure' mode in the printing preferences, Try reducing the YMC printhead power in printing preferences.
magicard
Magicard
  • 71 Answers
  • Posted on Jul 18, 2008
SOURCE: Printer issue...:(
Hi MaCaTa2,
It can be frustrating when things aren't going smoothly.
Sounds like you're wasting a lot of dye film and cards too!
What program are you printing the badges from?
You have a very 'paper' size with this type of printer.
If you select 'Magicard Printer Series' as the printer, you will then see a special paper size called 'CR80 Edge To Edge'. This is basically the size of a credit card. (2 1/8 x 3 3/8" (54 x 85.6mm). Check your font sizes are not too big. Any text printed on the back of the card is on page 2 of 2 (on the Tango model, a Rio would feed a second card).
Experiment with an application like MS Word, where you can clearly see the 'pages'.
Create a new word document, straight away go to 'File, Print', select 'Magicard Printer Series' from the printers list, then 'Close' (not 'Print'). Next, go to 'File', 'Page Setup', for the paper size choose 'CR80 Edge to Edge', set all the margins to '0' (this is a 'full bleed' printer.
You will now see a credit card size page to work on. If you fill this page (or insert a page break), you continue onto page 2 (the card back - only available on Tango).
I hope this helps.
Regards,
MC.
magicard
Magicard
  • 71 Answers
  • Posted on Nov 12, 2008
SOURCE: Magicard Rio ID 2 Card Photo doesn't fit in the pre printed space on the card
Hi There,
Could you scan one of your cards and insert the image in your reply?
Just a dummy card will do. It helps to be able to see the problem.
Which application are you printing the badges from?
The image position is only for very small 'fine tuning' adjustments to the card start and end positions.
Regards,
MC.
TimeDefensiv
Shahzad Waseem Akbar
  • 746 Answers
  • Posted on Oct 30, 2011
SOURCE: i did a self print test doesnt work on a magicard 100 printer
There is the problem with the toner, so please replace it.
Thanks
131 students in my school. 80 of the students passed. What is the percentage? How do I set it up?
Divide the number that passed (80) by the total student population (131). This will yield the percent that passed (,6106), Multiply by 100 (shift the decimal point two places to the right) and the result is 61.06%. Rounding to the nearest number equals 61%.
(x/y)*100 (80/131)*100=61.06 % ~ 61%
Hope this makes sense.
Need a free download of Microsoft Office Home and Student 2007 or 2003, badly for school. Don't have any monies to purchase one.
If you can run a School then you can manage to buy MS Office too. why don't you use some Linux Operating System which contain application similar to MS Office. And it is Free of cost also.
I brought a computer for my son, it had Microsoft Vista installed and 2007 microsoft Home & student, no he needs to use it for college and I dont have a product key to use.. How do I get one?
You unfortunately have to buy a copy if you want Office in particular. However there is a free alternative that edits and can create Microsoft Word / Excel files, it's called Open Office and is completely free and works the same way. It can even open files that other people (students / teachers) create with microsoft office. He can buy office at a student discount from the student bookstore (if his school has one), but I recommend you just use Open Office, I will provide the link to download it below.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Here is the link for open office:
http://www.openoffice.org/
Go there and you can learn about it, and download it for free right from the homepage.
Thanks
Tim
Need a product key for microsoft office home and
malestrom_36
In regards to the product key for your Microsoft Office Home and Student addition the key should be on one of the CD covers. If you got the Office as a download from your school then they will have the product key posted some where for you. In most cases it will be on your student profile page that you downloaded the Office from.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
I need the product key for microsoft home and student 2007
queenbrat14
If you purchased the laptop with a student version of Office the product key on the notebook is not going to work. You will need to go back to the store/person that you got the computer from to get the key. The student version comes in 2 ways in a CD format which the key will be on CD 1. The other way is a download from the school that the student got the version from and the key would be in their person on files with the school.
Now if you are needing the Windows 7 key make sure that the key on the system is not for another OS. If it is you need to get the right key from the store/person you got the computer from and/or have them reinstall Windows with the proper version for you.
Hope this helps
Issken
STUDENT 2007 error message
Is it a trial of office?
Will it allow him to save anything?
Try to activate the Office.
Top Magicard Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
