Question about E-Machines eMachines Desktop PC
I would like to wipe out my computer and start over can i do that
Posted by josephamy99 on
Anonymous
  • 94 Answers
Hay,
To wipe out everything on your computer is to Format it and to do this on your E-machine,follow this instructions.
First, check if its set up in RAID O configuration and you have your recovery disc, if it is, then all you have to do is watch the screen when it boots up for you to hit the F1 or F11 function keys which would you the option of a destructive or non-destructive format and you choose the non-destructive and simply follow the instructions.
Second,if its set up in Windows, then you need to get the Windows operating system CD and put in the CD drive of your machine, Restart your computer and press any key to boot from the CD,Click Install when you see the install dialogue box and enter your product key when prompted,click 'next',accept the licence agreement,click 'next' again,Click 'custom' when asked the type of installation,click on the emachine hard drive and select the format button and the entire hard drive is formatted.Click "Next" and Windows is reinstalled on the computer. Follow the onscreen instructions after the computer restarts to complete the installation. Once installed, your eMachines T5010 is completely reformatted and returned to the state it was in when you first purchased it.
Posted on Sep 14, 2011
fanaudi
  • 1,381 Answers
Hi josephamy99
Yes , you can . Launch the install disc and follow instructions .
Note : back up all your data and drivers ( very important , the drivers , some hadware could not function if you don't reinstall the drivers on your new system ) .
Best regards ,
fanaudi .
How can i wipe my entire computer clean and start new?
Hi, have you got clean recovery disks for your computer? Simply put disk into your disk drive and start recovery computer. All data will be erased only system will be like in new computer.
Aug 23, 2014 | Microsoft Windows Vista Home Basic Edition...
How to format windows xp i3 processor with dh55pj mother board
If you are wanting to wipe the laptop, then I suggest DBAN.
1. Download the .ISO from here. http://www.dban.org/
2. Burn it to CD
3. Boot the CD on the computer that you want to format.
4. Once DBAN has loaded, type "autonuke" and press return to start the program.
5. DBAN will wipe the data from all disks attached to the computer.
Oct 22, 2012 | Computers & Internet
It occured problem that cannot open it windows and atomatically shut down and repeated again and again
This normally happens if the operating system has become currupted. Your best bet is to do a factory restore (wipe the computer) and start over. This of course will wipe out any information on the computer you have added.
Jun 29, 2012 | Samsung NC10-14GW PC Notebook
Computer was wiped and I am trying to also figure out how to get a boot disc from toshiba. it was never with the computer to begin with.
you don't need a start up disk from toshiba. A regular Windows instalation CD/DVD is enough.If your computer was wiped, there's a chance the Toshiba startup disk will not start either.
If you use an OEM version of your Windows (have a windows key sticker on your laptop), then download an OEM Toshiba version. Use this LINK for more information.
When you have the Windows CD, you just need to repartition the disk and reinstall windows.
Feb 18, 2012 | Toshiba Computers & Internet
Won't start
the wipe out probably removed your operating system too.install a new os
Jan 05, 2012 | Toshiba NB305-N410BL 10.1 inch Mini...
Subaru impreza 1.6 2005- car was flooded about 4 inches inside. ECM programs were wiped out. Reprogrammed computers. Car statred and run. When swithed off, did not restart. Found that the programm was...
You must ensure everything is dry, including wire harnesses and realy/fuse boxes!!The computer may have gone bad or internally its has moisture!!
Sep 26, 2010 | 2005 Subaru Impreza
SHOWING FATAL ERROR? I CANT UNINSTALL. WHAT I DO?
When did you get this? If you have no data, just wipe and start over. If not, you could take the HDD out of the computer and connect it to another computer through USB (http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002) and get all your data, then wipe and start over with a fresh install.
Dec 29, 2009 | Microsoft Windows Vista Ultimate Edition
How do you wipe the compaq presario m2000
I'm not sure if you are wiping it to start over or to sell/give away.
Many newer machines have a Recovery Partition, usually your "D:" drive.
Access the System Recovery partition from the Start-All Programs-System Recovery-System Recovery Menu. Following the prompts will allow you to reformat the computer and reinstall the operating system and all software as it came from the factory. From that point, if you don't want any of the factory junk, you'll need to uninstall it yourself.
If the Recovery partition is missing, (usually a D: drive) , then you'll need to have the original Recovery discs which were created when the computer was new.
If you simply want to wipe it, use a disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads.com to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
disk wiping tool. Many hard drive wipers, cleaners or shredders can be downloaded at no cost. Visit Downloads to search for these programs that are designed to wipe your hard drive. Once you have downloaded a disk wiping program, install it on your computer. Each program will have a unique graphical user interface (GUI) and directions for use. Follow the directions for your selected disk wiping tool and run the program to wipe your hard drive. The program will make sure that all files and data have been completely erased by overwriting the entries multiple times.
Read more: http://pcs.suite101.com/article.cfm/wiping_your_computer_hard_drvie#ixzz0RZDlV3Qr
Sep 19, 2009 | Compaq Presario M2000 Notebook
When gateway computer model Ma7 starts it says a read disk error
Usually if you have the install disk for the OS you want it will allow you to wipe the disk during the install
Sep 10, 2009 | Gateway MT6705 Notebook
Gateway laptop computer freezes during system recovery
Turn the computer off, then start it back up and press the f2 key repeatedly til a blue screen called the BIOS screen comes up, press the right arrow on your keyboard so it goes to the advanced tab. go down to speedstop and disable it, press f10 to save changes and start computer over. Now it will work no freezing :)
May 31, 2009 | Gateway MX8711 Notebook
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
