I have cracked many codes by just feel and using the lever to feel the drop! The first right turn after three complete revolutions of the dial has one long pause and the rest short! After the long pause is the first in the combination, the left one same thing after one complete revolution, then right again pulling the lever down every drop meticulously. DONE!
SOURCE: Sentury Fire Proof Safe 1250
I concur with ohiotom but I will use this as a suggested solution in order to get this off the board.
You have to contact Sentry directly to get another combination
Sentry Safe
1-800-828-1438
www.sentrysafe.com
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
SOURCE: Forgotten Default Combination
Per sentry's website (link below)
If you need your combination and did not previously register your combination on our website, you may request your combination from our Customer Care team. Please send a notarized letter stating you are the owner of the safe. (Note: the owner�s last name must be different from that of the notary public). For locations that require a raised notary seal, use a pencil to shade the seal to insure that it is visible when faxed. The notarized letter needs to include:
Please note: Your combination will be sent to you within 48 business hours of receipt of both the notarized document and payment.
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
SOURCE: Father has lost safe combination to Sentry 1250.
try looking under the thesafe see if it has a reset button or u could read the sticker(if there is one) and see if u could get the store that u bought it from, to reset the combo
SOURCE: How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
