Good day!!!!
That problem is usually cause of faulty capacitors on the power supply section..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
The problem is the High Voltage block and I tried the tvrepair site no help. can you help locate sony part#8-598-955-12 anywhere
you can buy it to this site..
http://www.encompassparts.com/products/?...
worth $38.40
Thank you hope it helps..
Mr. pendilton,
thanks for the info on encompass parts but they don't have it and I'm hoping you might know of another place else that may have one sitting around.
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen slightly.
