This happens when no signal is received by the monitor.
Most of the time this is a problem with the VGA. It could be a problem with RAM also.
If you can, remove the VGA card and RAM(s). Clean the VGA slot and RAM slots with a small brush. (You can use a blower also, but I prefer the brush).
Re-insert the VGA and RAMs.
Restart the machine and check.
If this doesn't help, you may have to replace the RAMs or VGA.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at [email protected], Thanks,JT
