Question about Yahoo Mail
Finding diffeculty in attaching file in e-mail
Posted by opkapoor28 on
Muhammad Asim
    New Friend:
  • 89 Answers
Dear Friend... After Reviewing your problem... I will suggestion you.. Its may be reason.. 1st is that.. u are facing difficulty to attaching file , so may be its your Internet Connection Speed Depends. its will low speed, or 2nd is that . may be u are trying to attach file more then 10MB size.. its very clearly mention... the attaching file is must be less then 10MB... so Check it.
Posted on Sep 14, 2011
I'm unable to attach photos in an e-mail on my Windows Vista laptop. I click attach (files) and nothing happens.
hmm that is part of the email application that you are using some of them need a bit of time to find the file and attach them usually showing a progress bar while attachment is done
what email reader are you using?
May 24, 2012 | Computers & Internet
I want to attach & send pictures in my yahoo
There are two main theme in yahoomail, one is "Classic" and the other is "All New Mail"
To attach file/photo from classic, Click new or compose and look carefully just below the "subject" bar, there you'll see a button "Attach File", to attach file, click on the button, browse the file and follow the instructions.
Similar procedures for the "All New Mail", the difference is only the "attach file" button location, after you've opened the compose or new, look at the top columns, you'll see, "Send" "Attach" etc,, just above the "To" box. I hope this helps. Good luck, Thanks for using FixYa.
May 30, 2010 | Yahoo Mail
DONT HOW TO E MAIL A SCANNED DOCUMENT
  1. Step 1 Go to your e-mail program.
  2. Step 2 Click the New Mail, Write Message or similar button, depending on your application to create a new e-mail message.
  3. Step 3 Enter the address of the recipient in the To field.
  4. Step 4 Type a subject in the Subject field.
  5. Step 5 Add a message to the body of the e-mail as usual.
  6. Step 6 Click the Attachments button. Many programs have an icon of a paperclip for it. Also look for an Insert File or Insert Attachment option in the File menu.
  7. Step 7 Browse your files to find the attachment you want to send. You may need to click on a Browse or Find button to see your directory.
  8. Step 8 Click on the filename. If your program allows you to attach more than one file at once, hold down the Control key (or Shift key on a Mac) as you select another one.
  9. Step 9 Click the Attach Insert or Open button, depending on your e-mail program.
  10. Step 10 To send another file from a different location, click the Attachments but-ton again and repeat the steps.
  11. Step 11 Click the Send button when you're done.
May 28, 2010 | Lexmark X2500 All-In-One Printer
Iam not able to attach documents/files in my yahoo mail box
Reset browser... Tools >> Internet Options >> Advanced >> Reset
Mar 28, 2010 | Yahoo Mail
How do i attach mail from word document to email
Save the file in Word.
(Note down the location of the folder where he file is saved)
Login to your email account
Start a New Email
Do the usual steps.
You will see a button which says "Attach File"
Click on that button
Click on the word "Browse"
Locate the file you want to attach.
Once you find the file, click on it, and click on Open.
Now the file will be attached to the mail.
After attaching the file, click on "SEND" to send the file.
Hope this will work for you.
If you find this answer helpful, please give a rating.
luciana44
Dec 28, 2009 | Yahoo Mail
Can I email my projects if I am using MSN.Com email? how do I set that up in control panel?
  1. tep 1 Go to your e-mail program.
Nov 15, 2009 | Broderbund PrintMaster Platinum Version 18
How can i get a picture from one of my folders to email it to someone?
Most email programs have an 'insert' function. Click on it, then find the photo you want and click on it then OK. The image is then an attachment to the email.
Sep 29, 2009 | Computers & Internet
How to send pictures by e-mail with PhotoTag Express? Have Outlook Express e-mail.
you go to attach file in the email and find the files you want to send then go to attach files
Mar 07, 2009 | Dell Inspiron 1501 Notebook
What is the procedure for sending pictures over the Internet in FinePixViewer?
To send a FinePixViewer image file in an e-mail message as an attachment, Microsoft Outlook Express or Microsoft Outlook 2000 e-mail software is required. 1. In the "My Computer" window on your PC, select "Internet Options" in "Control Panel" and click "Programs". 2. Check that "Outlook Express" or Outlook" 2000" is displayed in the "E-mail" field. Attaching an image file to an e-mail message 1. Launch FinePix Viewer. 2. Select the folder containing the image file in the folder tree display area on the left. Thumbnails of the images in the folder appear on the right. "Outlook Express" or "Outlook 2000" is displayed in the "E-mail" field. 3. Click the thumbnail for the image file to be attached to the e-mail. To attach multiple files, hold down the [Ctrl] key on the keyboard and click the images to select them. To deselect an image file, click the image again. 4. With the thumbnail for the image file to be attached still selected, select "Mail sending" in the "File" menu. Your e-mail software starts up and the image file is attached to a message. Fill in the destination address, title and the message body, and then use the usual procedure to send the message. * images files sent using FinePixViewer can be no larger than 1 MB and no more than 10 files in total. If the total file size is greater than 1 MB, a warning message appears when you click [Mail sending]. If the files are too large, decrease the number of files until the warning message no longer appears. Note also that you should not exit FinePixViewer until mail transmission is completed, otherwise it will not be possible to send the e-mail message with the attached image file. * Some service providers place limits on the sizes of files that can be attached to an e-mail message. The transmission of large image files can also take a considerable time. Select "Mail Transmission Settings" from the "Settings" menu in FinePixViewer and resize the attached image files so that they are no larger than necessary.
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Yahoo Mail Logo
43 people viewed this question
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
