This tip i wrote explains exactly what the F1 error code is and what should be replaced.
http://www.fixya.com/support/r10005546-f1_code_means_oven
The part number for the touch pad on your model is 316101103 its only available as part of the clock/control asm.
Hello wills_amber - Typically, error code F1 indicates that the range has detected a runaway temperature issue (overheating). Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) on the range will need replacing.
