Question about Toshiba MD13M1 13 in. TV/DVD Combo
Would like to know if my toshiba model 20AF46 will need a converter box fo receive digital signal?
Posted by melonhd1 on
Loretta Northcutt
  • Toshiba Master
  • 736 Answers
Yes you will need a converter box. This television does not have a digital tuner. It does not have an atsc tuner. It does not have a qam tuner.
Posted on Sep 14, 2011
I don't have cable TV, so do I need just an antenna or a digital converter box to be able to watch this TV. The Make & Model # is: TOSHIBA LCD TV/DVD Combination & 27HLV95
The TV has NTSC (analog), ATSC (digital) and a ClearQAM (digital unencrypted) tuners. So you do not need a converter box. However, digital TV signals are either all or nothing (sufficient signal for the tuner to process the signal or a no signal message will appear). You should check antennaweb.org or tvfool.com for the channels that are available in your location depending on how the antenna is pointed. (Hills, tall buildings and trees may decrease the channels available in your location.) Antennaweb is very conservative in the list of available channels and assumes an external antenna. TVfool.com provides a list of channels (in each direction) depending on the type of antenna you have. (Indoor antennas usually don't get as much signal as external ones.) Antennas for sale have a color rating that matches the colors given by TVfool.
The manual for the 27HLV95 is available from Toshiba as a PDF: http://www.tacp.toshiba.com/tacpassets-images/models/27hlv95/docs/27hlv95_om_e.pdf .
I hope this helps.
(antennaweb.org indicates that my location will only receive two channels from a transmitter 10 miles away. With an external antenna, I actually get 10 (including the sub-channels) with the majority from transmitters 30 miles away.)
May 18, 2011 | Televison & Video
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Does Toshiba TiVo RS-TX20 accept the digital in February?
Any DTV Converter Box.
You Need a IR cable to control the DTV Box from the Tivo.
Repeat Guided Setup and select the correct DTV Box on the setup.
Jan 03, 2009 | Toshiba RS-TX20
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Dec 13, 2008 | Toshiba 36A50 36" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Toshiba MD13M1 13 in. TV/DVD Combo Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
