SOURCE: install A4 tech PK635 M web cam without cd installer
Hi
you can download the driver from this link, it will give you instruction as well, just select the driver for your Operating system
A4TECH
pls dont forget to rate solution, thanks!!
This for Faith - Follow the link below and on thr left side just click on the driver. Just save it to some place you know where it is and then install it. It has everything that was on the cd. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be glad to assist you further. Thanks and have a good day.
http://a4tech.com/ennew/download%20driver.asp
Jeff
This is nazir. I have enclosed the link for your A4 tech PK 635M Web cam. Can you please try it out.
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/A4TECH-PK-635.shtml
SOURCE: install driver web cam vf0250 whitout cd in windows xp
I found the driver. It is for some reason not listed at the creative
support page. A search for "creative vf0250" in Google revealed the
secret location though.
http://support.creative.com/Products/ProductDetails.aspx?prodID=14809
Notice VF0250 is mentioned in the title now.
Enjoy!
SOURCE: Veo web cam
Normal
0
You need to go to the manufactures site and download the VISTA
driver for the camera. Then follow the info below to install
the program.
Try disconnecting the Camera from the USB port and reinstall
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
