Question about Braun Health & Beauty
Hi The trimmer is replaceable and can be purchased as an assembly. You will need a T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the old trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract. Please get back to us if you have further query or else please accept the solution.
Posted on Sep 15, 2011
Really? Is there a diagram or schematic of this shaver? This seems to be a common problem.
Where can I buy the replacement? I have exactly the same problem!
Amazon has the part for $25
