Question about Garden
I can't get a carby for a Honda gv400 motor
Posted by mjpurcell1 on
patrick
Contact grant at honda spare parts in brisbane on 0738056833
Posted on Oct 23, 2012
russbezanson
    New Friend:
  • 24 Answers
Cantact honda directly, they should help u. I've contacted them myself, there a great company one of the few that still know what customer service is. Good luck
Posted on Sep 14, 2011
Silly ? But do you screw the dip stick in on the Honda gv400 motor ?
If there are threads on the mover and the dipstick then yes. If there are no threads then no. That being said most dipsticks do not thread into the tube as this makes the readings less accurate by a small amount
Dec 03, 2017 | Honda Cars & Trucks
My honda xr2600 pressure washer stops running when i pull the trigger
check for a blocked main jet in the carby
the principle is that when the trigger is released there is no pressure in the pump so the engine is idling
when the trigger is pulled the pressure control valve closes the bypass back to the pump and so the motor is loaded up if there is a problem in the carby ,then the motor will stall
Sep 08, 2015 | Honda Garden
Honda em3500x Genarator bad noise
check for blockage in carby bowl. sediment etc blocking the main jet and restricting flow under full load causing the engine to fluctuate in revs
Jan 29, 2013 | Cars & Trucks
My 150cc dune buggy idels when i turn it on but whenever i give it any rev it just putts out and turns of
have a look at the motor carefully and try and see if the motor is a licensed copy of any other bike engine, e.g the chinese bikes copy honda's CG125 and CBR 125 engines, i know in japan and other places around the world they use CBR 150's which is just a bored out 125 motor.
if it helps find the manual of the bike in question and look at the set up for the carb and try it, but based on what your saying depending on the carb type
i'd suggest moving the carb needle down a notch as its seems to be getting too much fuel.
Sep 28, 2012 | Motorcycles
Bike has a spark and cleaned out carb will not start, put fuel in plughole would not fire, it just stopped when going on road, charged battery, so it turns over well, checked valve in petrol tank vaccum...
if you have good blue spark and it fires when fuel is added externally , then the problem is fuel flow through the carby
have the carby professionally overhauled or get a new carby
make sure that the gasket to the manifold / head is in good condition
May 06, 2017 | Honda Runner Pure Jet Motorcycles
Looking for spare parts for morrison rapier 710 self propelled slasher specifically a working carburettor . where can I find grave yard of retired MR710 slashers which retain some useful parts. Engine is a...
firstly you are the only person i know of with a mr710 other than myself mine still has serial no on it 00054.To me this says not many made. i could not find a blade for mine so done my own mods with cox swivel blades but do not know of any others in australia. I can not even find any info on net. honda motors with vertical shaft are not common but never give up like all hondas. try the mower shops as an alternative. hope this may help
Apr 24, 2009 | Garden
Garden Logo
217 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
