Heidelberg Linoscan 2200 Flatbed Scanner Logo
Question about Heidelberg Linoscan 2200 Flatbed Scanner
I need updated drivers - Heidelberg Linoscan 2200 Flatbed Scanner
Posted by eugene_judah on
hamster47
  • 739 Answers
Check out Hamrick Vuescan. they have drivers for almost every scanner made. http://www.hamrick.com
Posted on Sep 13, 2011
tip
Some important tips to update your computer drivers
<p><span>Computer drivers</span><span> are useful for your <span>computer</span> run smoothly with some hardware such as hard drive, CD/DVD drive, Graphics Card, USB and other components of your <span>computer<b>.</b></span></span><br /> <p><span>So it is important to update your drivers when you have a <span>computer.</span> These are tips that how to update your drivers, it will help you to find the problems in your <span>computer</span> when you run some applications. It is important to ensure that they work perfectly with your computer.</span><br /> <p><span>If you facing some problems with a device, it may cause of need a driver update. If you have other software on your computer, you may need to update drivers, for it's running smoothly. </span><br /> <p><span>Here are some tips<b> </b><span>that will help</span> you to update these drivers. </span><br /> <p><span>The first thing is to know about your driver, there are different drivers on your computer. If we have knowledge of what we need and which hardware required drivers to update, it helps you to find what is to be updated. </span><br /> <p><span>The driver for your <span>computer,</span> such as scanner, DVD, printers, video, audio, USB, webcam, digital camera, and others can also your Windows drivers, if you run on the operating system. </span><br /> <p><span>You should make your equipment familiar. And do not take too much to go into the depth details of them, but having working knowledge can make your easy. Here are some product online and find it that will takes to be a smooth process. </span><br /> <p><span>Everything you need to do is available in start menu click on window update button.</span><br /> <p><span>The manufacturer's site will help you to get the drivers for your PC update. You must ensure that you at the exact same model of the device that you looking for update. </span><br /> <p><span>If you do not want to search driver updates online and during the test, then you can go to software that automatically update all the drivers on <span>your computer</span> and keep its equipment running smoothly. This process may be the easy and simplest way to update your drivers quickly.</span><br /> <p><span>By using these operations your Computer will give you best performance.</span><br />
on Dec 24, 2010 • Computers & Internet
If im missing a driver when i do the updates will it fix it?
Maybe, Windows Update does have some drivers; you will need to open the Windows Update control panel and check for optional updates. (Windows+X, select Control Panel. Go to System and Security, then select the link for Windows Update.) Check for updates (on the right) and then look at the list of Optional updates. Check the ones that you need.
Be careful: sometimes Windows Update provides the incorrect driver. If you need the drivers for a specific device, check with the manufacturer or post a comment with the manufacturer and model.
I hope this helps.
(Windows Update has successfully found the drivers for my older printer and scanner to go with Windows 8.1. Unfortunately, last week I had to hide an Network adapter driver by right-clicking on the update that was from an unknown company.)
1helpful
6answers
Where can i update my xp drivers for free?
All updated drivers are available free from the various manufacture's websites.
Need updated driver for super multi dl dvd acer aspire 5735
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
1helpful
Update drivers for my tavelmate 2300
Good Day,
To update your Travelmate 2300, just go tho this site to download and update your drivers as needed. Just be sure to check your current drivers version, you only need to update old driver versions. Just click on the links provided on that link for the drivers you need to update.
http://support.acer-euro.com/drivers/notebook/tm_2300.html
Hope this helps you. Thank you for using Fixya.
3answers
I NEED WINDOWS 7 COMPATABILITY DRIVER SOFTWRAE FOR MY PC
Connect printer to computer, turn on and then go to windows update. Search for updated drivers and you will find it. You need to do this while runnind add printer wizard
Rob
Please rate. thx
4answers
I installed xp on my hp a6683w and it does not have the driver for the network card. i cannot get it from hp because it was a vista machine. where can i get the driver
Most HP and Compaq computers come with full versions of Microsoft Windows preinstalled. Microsoft has an extensive library of software, drivers, and updates available for free download. HP and many of its partners work with Microsoft to provide drivers through Windows Update. Use the following steps to download drivers, software, and updates by using Windows Update:
  1. Connect to the Internet and see http://www.update.microsoft.com (in English).
  2. Follow the directions in the Windows Update page to set up Windows Update and install the software updates.
  3. Be aware of the following tips when using Windows Updates:
    • Install all critical updates first to help keep your Internet connection secure.
    • If you are looking for drivers, they can be found as optional updates from the list of available updates.
    • Due to file sizes, number of updates, and download time, use Windows Update when the computer is not being used for other activities.
For more detailed information about using Windows Update to install drivers and get updates for Windows software, see the HP Support document Updating Drivers and Software with Windows Update .
NOTE: Another great way to quickly get updated drivers from Microsoft is to open Device Manager, right-click the name of the device, and select Update Driver Software . Updating a driver from Device Manager c01162470.gif
3answers
Missing dvd driver
after you update the BIOS
update the DVD firmare
update the driver for flash reader...i believed you have Texas instrument reader and they have update driver for xp and vista
after you update the driver ..check also the hardware update for microsoft...do custom update when you access windows update
Top Heidelberg Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
