You may have the humidity extraction level set to HIGH. Try lowering the humidity extraction level to 35% or if you have an analog unit, turn the control knob to maximum. Also cleaning the air intake filter may help.
Hope this helps you to solve the problem and thanks for choosing FixYa.
Bonnie, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air
temperature at floor level is colder than at shoulder level in basement applications . Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
Hope this helped you tho troubleshoot and solve the problem. Please let me know. Thanks.
MOst likely the room the dehumidifier is operating is is too cold for proper dehumidification to take place. Try warming up the room and I believe then your dehumidifier will work fine.
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
sound like a sealed system issue , if the compressor is running and no moisture is being deposited into the bucket there is an issue with the sealed system that need pro help
