Question about General Electric WHDSR316G Top Load Washer
I have a GE washer WHDSR316G1WW and I cannot get a new belt installed. How do you install the new belt? It barely fits around the large pulley.
Brandon Amison
    New Friend:
You are correct in that the belt seems overly tight. This is what I did.1) Get the belt on the large pully2) Using several ZIpTies every few inches, secure the belt to the pully3) Get a metal hanger and loop it through the belt making a safe handle at the end.4 Cover the handle with a cloth to protect your hands and to also provide grip.5) Have my 300 lb, 6'7" hulk of a son pull as hard as he can while you assist getting the belt on the motor spindle.
Posted on Aug 15, 2012
4 Related Answers
Anonymous
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
Anonymous
  • 104 Answers
SOURCE: i have a ge washer model whdsr316g1ww. the belt
Have you loosened the motor mounts to help swing the motor closer to the pulley? If you have is something blocking the motor moving further?
Some belts can be a bit tight to get on so hook it up on the motor pulley first and then get one side on to the main spider pulley and then turn the main spider pulley to thread the belt on. Providing the belt was in its original grooves on the motor pulley as you turn the spider to get the belt on it will cetre itself. Then tension the belt by pulling on the motor and tighten the bolts. DON'T OVER TENSION THE BELT AS IT CAN SNAP IT OR THE SPIDER PULLEY!
Posted on Feb 25, 2010
Anonymous
SOURCE: cannot get drive belt on
I have a front load kenmore washer. Initially the machine didn't drain the clothes fully, then the belt came off. The belt will not stay on. Help
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: my washer won't agitate or spin! I hav a GE washer
Might be a blown line fuse located in the red and white wire in the harness, you will know it if the green idiot light on the motor ain't a blinkin.
Got questions? I will be here all week.
Rate the answer and thanks fer using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 13, 2010
GE WASHER BELT TOP \DSR LOAD WHDSR316G1WW
put the belt on the motor pulley then start with the other end on the drum pulley and turn it with your hand , i hope this makes sense . the object is to let the pulley do the work of stretching the belt into position
2answers
I have a broken belt 175D5131P003 on a GE washer Model WJRE5550K2WW, or a P620. I realize the belt will have to be stretched a great deal to fit over the drum pulley and the motor shaft, but cannot figure...
Hello & Welcome to FixYa
You can view this video for replacing the belt in your GE washer:
Please get back to me if you have any other questions.
Kevin
I have a ge washer model whdsr316g1ww. the belt seems too small cannot get it around pully. ge said i have the right belt.please help!!
2helpful
2answers
How do you replace the belt on a GE wwse5240g washer?The motor will not move without it being out of place to put the belt on. Does the pulley move?
The easiest way to install a new belt for a GE washer of your model is like putting on a bike chain.
**First unplug the unit.**
Then remove the front panel if you haven`t already.
Now rap the belt around one side of the motor pulley then get it started on the drive pulley. Hold the belt in place while spinning the drive pulley (watch your finger`s the edges are sharp and when the belt slips on it`s very tight...pinching could occur) and the belt should slip in place. You don`t remove the motor or even loosen it, it`s not necessary.
Good luck
macmarkus :)
1helpful
My washer wont agitate or spin
If this machine is a drum type and NOT A TOP LOADER (There was no mention of the model) then the overload has possibly caused the drive belt to either break or jump off the drum pulley.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
If the belt has slipped off or has broken, it can be replaced by fitting the (new) belt around the motor drive pulley (small end) and refitting around the drum pulley, you can do this by feeding the belt around the drum pulley, by holding the belt in place and feeding onto the pulley (IT IS EASY TO GET YOUR FINGERS NIPPED BETWEEN THE BELT AND LARGE DRUM PULLEY WHEN ATTEMPTING TO FIT BELTS BACK - SO BE VERY CAREFUL)
Best of Luck!!
1helpful
How do you install a new belt? its hard to fit around !!
Youmust loosen the motor bracket bolts and this will allow the motor to swing. Put belt on the motor pulley and feed the belt onto the large drum pulley and at the same time turn the drum pulley so that the belt pulls onto the pulley groove. Put some tension on the motor to tension the belt - not too much tension though. Holding the motor & belt tension, tighten the motor bracket bolts - job done. Should take no more than twenty minutes to complete.
Belt
rear access cover, remove and hook belt around motor first then around pulley while turning.
GE Evolution = How to remove the Clutch Assembly for new belt
Actually, you just need to place the belt around the motor pulley and get it started around the larger pulley and move the belt clockwise while keeping it on the larger pulley. it will self thread onto the large pulley as you spin it.
Good Luck!
1helpful
How do you install belt on a kenmore front load washer model #41743042200
Goes on motor mpulley first then roll it onto large; it's tight but fits. Adjust position of belt on motor pulley grooves so it rides centered on large pulley. Make sure large pulley is not warped; replace if it is. If belt came off on you buy a new one. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
1helpful
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
General Electric WHDSR316G Top Load Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
