Garden Logo
Posted on Sep 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a mcculloch washer # fhh18a / fhh20c. pump will not turn on all of sudden.
DROPNDEAL
Level 3:
Top Expert:
  • McCulloch Master 2,931 Answers
  • Posted on Mar 10, 2018
DROPNDEAL
McCulloch Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
932554
Points
21770
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
3 Related Answers
Alan Myers
  • 19 Answers
  • Posted on Sep 14, 2009
SOURCE: Where can I purchase oil rings that go into the
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Oct 18, 2010
SOURCE: I need a manual for a McCulloch pressure washer
Your manual can be downloaded from here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2006/MOUS2006_7096H18A01.pdf
If the above link does not work start here: http://www.mccullochpower.com
Which should get you to this page where you type in FHH18A as the model number
http://www.mccullochpower.com/node7877.aspx (Use for ANY McClloch
Course of last resort.... Call them at this number: 1-800-521-8559
Thanks for choosing FixYa,
Kelly
Asbestos 56
Ron
  • 195 Answers
  • Posted on May 16, 2011
SOURCE: I have a McCulloch FHH18A
I would guess there is a leak somewhere inside the unit that is spraying water on some electrical component and causing a ground fault.
How to clean pressure washer pump
Contact us
User manuals McCulloch Service
I trust this information proves beneficial.
I broke the nozzle on my FHH18A pressure washer and I need a new one
Well, you know you can just buy one right? Try the links below:
Contact us
User manuals
McCulloch Service
Need replacement part 7154-180A01 for McCulloch FHH18A Pressure washer
Contact us
User manuals
McCulloch Service
McCullock Powerwasher FHH18A - All hooked up, but pump won't turn on. Is there another switch/button somewhere?
look for 2 things. 1. the GFCI button on the plug, you may have to press the 'reset' button to turn it on. 2. there may be a reset button on the motor or the unit somewhere this will usually be round, and often red, but maybe black also. hope this helps
2helpful
I can't find the directions and need to know how to get the cleaning solution to come out of the machine.
You can download your manual here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FHH20C-7096H18A03-966990001.pdf
Instructions for chemical tank 1 and 2 use are on page 6. Wand must be in the low pressure position to dispense chemicals.
Thanks for using FixYa.
Kelly
Kelly
3helpful
Pump burned out?
Contact us
User manuals
McCulloch Service
3helpful
Red light on power cord stays on powerwasher wont turn on
The red light means you are getting power. It sounds like the bypass (unloader ) valve is stuck. This is inside the actual pump
2helpful
I have a McCulloch model number FHH18A/FHH20C. The brass fitting that comes out of the pump has broken. It's brass and plastic. McCulloch claims there is no replacement part, except to purchase a new pump...
Same problem, water intake brass fitting, a 90 degree to connect a hose(barb fitting) to an i think 3/8 or smaller, i used an easy out and no luck.. i tapped it to 1/4 20.. so it may be smaller than 3/8 pipe or compression..inside there is still some of the fitting.. i cannot find the part online and cannot contact the 800 number, because they say google and good luck!
Jul 28, 2009 • Garden
4helpful
McCulloch M#FHH18A High Pressure Jet Washer,
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
