Question about Amana D545M Dehumidifier
I have an amana d545m in the crawl space at my lakehome...when i went to check on the furnace filter, i noticed it was not running and has no power...how and what do i check to diagnose the problem...thanks.
Posted by twsltd on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
First, make sure that there's power to the unit. Has a circuit breaker in the circuit breaker panel been tripped? If so, unplug the unit before resetting the breaker. Also, check the receptacle or extension cord that you're using to power the unit, as it may be damaged.
If you have power to the unit, it may be that some critter or insects have gotten into the unit and shouted it out. In which case, you're lucky that it didn't start a fire. It's not a good idea to leave the dehumidifier running unattended for a week or more.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Posted on Sep 13, 2011
  • Rich Landrum Sep 13, 2011
    Glad I could help you and thanks for the 3-Thumbs Up Rating. I really appreciate it.
Is there a recall on this product? My compressor and fan run but no water is collected. I know other Amana dehumidifiers were recalled for fire risk due to compressor overheating so I took cover off and...
Your description indicates a loss of refrigerant in the dehumidifier. The metal heat exchanger above the water collector should become cold when the compressor is running - if it does not, your dehumidifier likely has lost it's refrigerant charge. You will have to take it to a certified (refrigerant handling) technician to repair. It may make more sense to replace with a new dehumidifier.
Check the CPSC website for dehumidifier recalls. they will have details of the brands/models/serial numbers of recalled units.
Oct 23, 2013 | Amana D545M Dehumidifier
Where do you get Curcuit Broad D545N Dehumidifer and a bucket Switch
Its not worth the money. the cost of those two parts exceed the cost of a new one. Dont buy amana again they have very poor quality.
Jul 20, 2011 | Amana D545M Dehumidifier
DOES NOT COME THRU HOSE ONLY BUCKET
on your bucket you need to drill hole threw where the hose connect, or hose need to run down hill.
Apr 15, 2010 | Amana D545M Dehumidifier
DOES NOT DRAIN FROM HOSE ONLY BUCKET
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
I have the same problem--no water comes out.
make sure the front vent/filter is clean and free of debris. if there is not sufficient airflow across the condenser coil (front), it will not cool down. if it does not cool down, it won't remove the water from the air.
Aug 07, 2009 | Amana D545M Dehumidifier
Amana d545m dehumidifier no power
replace 24 volt 1 watt zener diode on circuit board. 1n4749 (nte5081a)
mine was hit by lightning and this fixed it.
Jun 23, 2009 | Amana D545M Dehumidifier
Amana D545M Dehumidifier Logo
228 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
