When I put my sim, I see "invalid IMEI" and my phone does not identify my network. I'm in Nigeria.
Posted by jasyjo02 on
Muhammad Asim
    New Friend:
  • 89 Answers
Dear Friend.. My suggestion is that.. its your mobile software problem.. so do flash your mobile. then it will work correctly... and your both problem will be solved.
Posted on Sep 13, 2011
Need unlock code for samsung GT-E1190. Im in australia and its locked to vodaphone need to use telstra sim
Unlocking helps to remove the network lock..So that you can use with other GSM Network sim card in it.IMEI Number is Unique for every mobile..IMEI means International Mobile Equipment identity.Using the IMEI you can identify the mobile phone model...It's unique for every phone.It will not same...While Unlocking you need to specify the brand ,model ,network,country it's locked now ,IMEI number
S/N is RF1C57WBP7B is serial number..
You can get the Unlock code for SAMSUNG E1190 model Phone at
Classicunlocking.com/samsung-e1190/rs17wp9/ and Unlock it from Vodafone network lock..Then use with Telstra Australia or any gsm network from any Countries.
Oct 08, 2012 | Cell Phones
Tip
Unlock codes for Samsung Sgh J700i
<span>1- Power on phone, type : *#7465625#<br />you will identify which code is active , which is inactive. <br /><br />2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone you must see " insert sim" not "invalid sim.." <br /><br />3- Type : *2767*3855# <br />your phone should restart after 1 min,<br />now, and before it restarts, push your sim card in, without removing battery. <br /><br />4- Your phone should work and accept the sim card ,, but if you chek locks you will find that your phone is still locked <br /><br />5- Now type : *7465685*638*00000000*00000000#<br />your UNLOCK CODE is 00000000 now , Enjoy <br /><br />6- Now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :<br /><br />* Disables CP lock : #7465625*27*00000000#<br />* Disables Network lock : #7465625*638*00000000#<br />* Disables SIM lock : #7465625*746*00000000#<br />* Disables SP lock : #7465625*77*00000000#<br />* Disables Subset lock : #7465625*782*00000000#</span>
on Dec 25, 2010 | Cell Phones
Invalid sim for Pantech go phone
If the PANTECH says Invalid sim it's locked to network...You need to Unlock it..Specify the network it's locked now,country...Then get the Unlock code
at Mobileunlocksolutions.com/pantech/rs1wp8/ and Unlock it easily..You need to specify the correct Pantech phone model also.
Sep 22, 2012 | Cell Phones
My phone shows "invalid sim"
If thats the case then your phone is locked for a particular network and globe is not one of them, you can try to use valid sim for your phone. Either try smart or sun cellular. Another solution is to unlock the phone by a qualified technician.
Aug 31, 2011 | Computers & Internet
"invalid IMEI", SIM not detected
Invalid Sim means get the Unlock code from service provider and Unlock it.....it locked to Network.
Aug 26, 2011 | Cell Phones
Sim not valid
Check IMEI by dialing *#06# if it is same as the IMEI written in the backside of the phone,Then the problem is from Sim card try with other Sim.In case IMEI is different please concern Mobile repairing shop.Thanks For visiting Fixya
Jul 25, 2011 | Nokia 1100
Invalid SIM
If your Phone says Invalid Sim while inserting the Sim Card means It locked to some Network,you need to Unlock the Phone from the Network Lock,To use any GSM network Sim card in the Phone,You need to find in which Country's Network it locked now? then what is Model,Brand ? specify those details and get The IMEI unlock code,i means Network Unlock code from here Mobileunlocksolutions and Unlock it,Using the Unlock instructions You can unlock the phone step by step also correctly without error....You can use any GSM Network Sim card in the Phone after Unlock it,You cannot use any CDMA network Sim card in the Phone after Unlock it...
Jun 27, 2011 | Computers & Internet
I have a nokia 5800 xpressMusic. Made in Korea. Imei is 352012042341890. I am not able to use it in Bangladesh. When i insert SIM card it says "INVALID SIM CARD" Please give me a solution.
Either your sim card is faulty, or more likely your handset is network locked.
You will need to either purchase a new sim card (if sim is problem) or obtain the network unlock code for your phone.
Feb 27, 2011 | Nokia 5800 XpressMusic Smartphone
Dear Sir or Madam My brother gave me BLCKBRY 7290 that he used in UK, but I cannot use it with my SIM card UCELL company, Uzbekistan ("invalid SIM card" note on the screen). What can I...
I am quite late in helping you but my information might help you in the future. If you want to unlock your blackberry, then I would recommend you Blackberry unlocking codes with IMEI. They are very reliable, CHEAPEST and provide good customer support service. Good luck!
Jan 03, 2011 | RIM BlackBerry 7290
When i switch it on, my nokia 3230 keeps restarting and most of the times displays "insert sim" and "invalid sim". Please help me. Thanks. Paschal, Nigeria
it may be due to network lock, contact service provider , else you can get unlock codes here http://www.theunlockarena.com/
you need to specify the phone model and network provider
Oct 08, 2010 | Nokia 3230 Cellular Phone
Computers & Internet Logo
35 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
